Question about Kenmore Dishwashers
Kenmore modle 665.1329
Will not drain
I have a Kenmore clothes washer. It shutoff midcycle and I can't get it unlocked. It acts like it has no electricity. I have tried the outlet and it is good. I have plugged it into different outlets and it...
is it a front load washer i think it is if so is there a panel under door if so remove panal 2 or 3 screws you will see a drain pump note un plug washer get a bucket unscrew filter plug slowley to drain water with washer unpluged reachup on right hand side you will fill the door latch on the bottum of latch there is a cord pull down that should unlock door then you can get modle number so we can figur out what went wrong
Mar 01, 2015 | Kenmore Washing Machines
I have a Kenmore He5t steam washer. I got the F35 code again, so I automatically ordered and replace the pressure switch again. did not fix the problem. I have checked and cleaned the drain basket and
Unfortunately you spent money unnecessarily, and before making any additional errors; it would be best to have a trained technician with knowledge of the washer, service the system.
Jan 18, 2015 | Kenmore Washing Machines
I have a side by side Kenmoore fridge modle 106.53652300. Water is collecting on the floor of the freezer.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 13, 2011 | Kenmore Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I need to get the front off my washer to see what is leaking when it drains it is modle 11092581200
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11092581200+
Also see the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Once the cabinet is off, I'd check the hoses to and from the pump as well as the gaskets at the bottom of the tub.
Nov 10, 2009 | Kenmore Washing Machines
Built in modle 665 does not drain
I am assuming that the modle 665 you are refering to is the first 3 characters of the model number???
if your unit is making all the normal noises it should make when draining, yet is not ejecting any water, or is leaving some and another drain cycle is necessary to remove all water the drain tube that screws into the pump/motor assembly may be cloged with larger than recommend particles that have made their way to it.. usually things like cupboard door bumpers that fall off into the unit get ground down till they fit through the chopper plate but are still to large to fit easily through that tube..
remove the kick plate below the units door, place a pan, etc under the drain hose where it connects to the tube, remove the hose, then unscrew the tube and check for obstructions..
hope this helps.
best of luck,
ttfn
Oct 24, 2009 | Kenmore Dishwashers
Model 501-64822 is a self-defrosting Kenmore that is building up ice in the freezer and then somehow melting and running down the inside of the fridge and onto the floor.Any suggestions??
Hi, Look that model # up again please. The problem you are having is the defrost drain is plugged. Remove the rear panel inside the freezer and melt all the ice. Locate the drain hole and flush it out with hot water. Some modles need an after market drain heater kit. Get me the model # and I can look this up for you.
Vic
Jul 04, 2009 | Kenmore 64802 Top Freezer Refrigerator
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kenmore Mod 110.26712693 Wont Spin
Pop off the trim pieces on the front edges of each end of the console. You will see the screws that hold the console down under them.
You can go to sears.com, click on parts, enter your model number and see a parts diagram of the washer.
Post back if you need further help.
Nov 17, 2007 | Kenmore 22422 Top Load Washer
Dishwashers Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
