Question about Healthometer Health o meter Glass Digital Scale Hdm545dq 37 (Health O Meter)
Healthometer scale model HDL951 DC1601 why doe s the E appear instead of my weight?
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
Recently when I step on the scale I get and E
Try stepping off when you get the E and step back on after 5-10 seconds and see if it works.
Aug 12, 2010 | Sunbeam Healthometer Body Fat and Weight...
How do i reset each individual person
mcdevito75 here, There should be a button or knob close to the indicator you can press, turn, to return scale to zero for each person.
Jun 26, 2010 | Sunbeam Healthometer Body Fat and Weight...
I just purchased a Healthometer Weight & Body Fat Monitoring Scale. I successfully setting up my scale, I think? When I turn the scale on and weight for the 0.0 to appear, I get on the scale and it...
These scales use sensors to measure the electrical resistance of the human body to calculate body fat. If you are not stepping on the scale barefoot then that might be the reason why it is timing out. These scales require you to step on it barefoot so it can take a measurement through your feet. And using the height and gender information in combonation with the resistance measurement it can calculate your approximate body fat precentage. If you are stepping on the scale barefoot then make sure that your feet are properly placed into the sensors and avoid any movement. Let me know if you have any questions.
Feb 06, 2010 | Health & Beauty
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
Healthometer Health o meter Glass Digital Scale Hdm545dq 37 (Health O Meter) Logo
131 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
