Question about Viper Security and Remote Start System (basic install included)
How can i reset the alarm on my viper 5104 remote
2 Suggested Answers
  • 1455 Answers
SOURCE: i lost my remote for my viper 350 hv,and when i
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Posted on Oct 08, 2010
2005 sedona alarm
Please be more specific. Is it the factory alarm going off when you remote start or, is it the Viper alarm going off when you start the car with the key?
Jan 24, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Problem just started sunday...when the alarm is armed it would show the locked sign on the remote....now it doesnt show that its locked and beeps like its not getting signal...but the car did lock with the...
I have the same problem. The easiest way around it is to disconnect the battery for 10 seconds and reconnect it. This will reset the alarm system, and the remotes will start working again.
Take note of your radio stations as they will reset. :)
Dec 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Nov 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
Sep 20, 2009 | Viper Security and Remote Start System...
My viper 2 way pager remote will not arm or disarm the alarm. it still shows a trigger when the door is open though. how do i reset the alarm remote to the vehicle?
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
Aug 18, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 771 Remote start/Alarm
the viper alarm is malfunctioning , it is supposed to bypass the key ignition and or chip in the key to allow it to start , you will need to look for a reset button( under the dash and just two wires going to the button)( stuffed under the dash ) ( not the switch) , this should let you start it but if the alarm components that control that bypass is to far gone then this will not help and the alarm will need repair , replaced or removed
Jan 25, 2009 | Viper Security and Remote Start System...
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
95 people viewed this question
Top Viper Home Security Experts
Kevin Daniels
Electro Med Services...
Are you a Viper Home Security Expert? Answer questions, earn points and help others
