Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
Sudden Power Loss
We were away for a couple of days and when we returned we found the unit had no power. None of the LED's light up (no picture or sound), we tried a different power source with no luck. The unit is about a year old.
  • 26 Answers
Most likely a problem on the sub-power pcb. If its under a year old it is still on parts warranty.
Posted on Oct 07, 2007
SOURCE:
Power loss and smoking
Toyota Hilux engine power loss Questions & Answers - Fixya
www.fixya.com > ... > Tags > engine power loss > Cars & Trucks > Toyota
Toyota Hilux cars & trucks engine power loss questions and answers. Ask your Toyota engine power loss related question. ... Question about 2006 Hilux 3.0.
Sep 27, 2015 | 2006 Toyota Hilux 3.0
I'm having same problem on my 2000 model rodeo 4wd 3.2L V6. Other day check engine light came on. I checked engine bay nothing abnormal, or power loss. Next day light was gone. 2 days later drivin
Where I live there is a Schuck's auto parts...and they have a hand held diagnostic tester that plugs right in to your harness. This will tell you whats is wrong.It only takes about 2 min and they don't charge you.On my car it was the mass air flow censor.If you can't find a Auto parts store that does this...take it to a shop soon. Good Luck
Mar 27, 2013 | 2000 Isuzu Rodeo
I have a panasonic toughbook cf-48. It was working and then all of a sudden it shut down and won't turn back on. I thought it was that the battery wasn't charging, so I bought a new battery. When I looked...
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 25, 2009 | Panasonic Toughbook 48 Notebook
91 900s Looses power, won't run through puddles/sudden power loss
Check all battery terminals and 12v power feed connections are clean and tight.
Check all battery chassis and ground connections are also firm and in good order.
Check any in line 'Maxi' fuse connections are firm.
Check for water ingress in any cable loom or bulkhead connector exposed to the water spray.
Sep 21, 2009 | 1991 Saab 900
Power does not come on stopped at once breaker is fine
get under the unit and make sure your wires are securely nutted together and that none have come apart... just one possible cause for a sudden loss of power.
Sep 03, 2009 | Whirlpool Dishwashers
Holden Rodeo 2001, check engine light keeps coming on!?
I'm having same problem on my 2000 model rodeo 4wd 3.2L V6. Other day check engine light came on. I checked engine bay nothing abnormal, or power loss. Next day light was gone. 2 days later driving, a sudden loss of power and light came up. After idling for a couple of minutes, drove off with light still on but all power back. 1 hour later of faultless driving loss of power for a minute or so. Engine temp normal. Had break for 1/2 hour and set off for last hour of journey without fault except check engine light still on. Following dayon startup light went out???
Seeking help from experts.
Feb 09, 2009 | 2000 Isuzu Rodeo
Sudden Power Loss
My conclusion: A modern TV breaking down within such a short span of time indicates one thing: It is an inferior product. I have made a mental note of the Sylvania product in order to not ever buy that brand again. If I am asked, I will be glad to share my experience with that name brand.
Nov 19, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
No picture on my Dell 790 monitor (17
Tom,
What you've got it a busted backlight inverter... need to replaced a new one or repaired it. To repaired, if you are lucky just replaced a couple of faulty capacitors in the power supply w/ built-in inverter... Good lucks, have nice day!
Oct 23, 2008 | Computers & Internet
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
69 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
