Question about TP-LINK Tenda W311R WirelessN Router AP 4port Switch 150Mbps
Why my wifi disabled to connect
It says on my password unchanged then trying to connect to my old password it wont and at the end disconnect my wifi it show what should i do to reconnect to my router
  • 826 Answers
To verify the wireless network connection status, please go to the Network Connection Window. For Windows XP, Click on Start. Click on Run. Enter "ncpa.cpl" and click OK. For Windows 7 or Windows Vista, go to "Search programs and files" box. Enter "ncpa.cpl" and hit the Enter key.
If you see the wireless network connection icon is disabled in the Network Connections Window, you may double click on it to enable the connection. Should it is still disabled an no way to be enabled, you may have a AntiVirus software (for example, Kaspersky, ZoneAlarm, Trend Micro Internet Security...etc) installed in your computer and it disabled the wireless connection.
You may completely remove the antivirus software from your computer and restart the computer. Check the wireless connection can be enabled. Then you can re-install the antivirus software.
Posted on Jan 21, 2013
2 Suggested Answers
DilshadB
  • 85 Answers
SOURCE: My ipod touch 4g will not connect to the router.
what you can do try to put " password " as the password its wanting and see what it does or else delete all the already connected AP (Access Point) on your ipod touch and see what it does..
Posted on Jun 01, 2011
Tip
What i have to do if its asking for a PIN Number when connecting a Belkin...
Hi Friends,
When you are connecting the Belkin router in Wireless,if it asks for PIN Number then please follow the below mentioned standard steps,
Step 1:Connect the belkin router to any one of your computer with an enternet cable.
Step 2:Open Internet Explorer and type 192.168.2.1 and click on Enter button in the keyboard.
Step 3:Now you will be able to see the belkin router page
Step 4:On your left side click on Wifi Protected Setup (WPS),now it will ask for password leave it blank and click on Submit.
Stpe 5:Now Change the WPS (Wifi Protected setup) to disable and click on Apply Changes.
Step 6:Now Try to connect the Wireless Networks in your wireless computer,it wont ask for PIN Number.
The above mentioned steps are the standard steps for the this problem.This is done because by default the belkin router's will be enabled with 2 security features so we have to disable any one of this feature.If you disable this then you wont have any Problem in the belkin router.
on Mar 16, 2010 | Computers & Internet
When ever i try to connect to the wifi on my trio stealth, it says authentication problems. what does that mean?
It would mean that the wifi you are trying to connect to is either password protected or will only work with specific pre-approved Mac Addresses (the hard code address of your device) It could be that you are trying to connect using a protocol that the router doesn't understand ie WEP. It is hard to tell without knowing if it is your router, how you configured it. how old it is etc. Your trio should be new enough to compensate for the older technology though so I would lean toward a bad password.
Jun 17, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
My arnova 10 g2 wont connect to wifi it authenticates, says rembered then drops out to disabled
try deleting connection and reconnecting with password. Other options is check your router for the number of allowed users on wifi.
Dec 09, 2012 | Archos Arnova 10 G2 Tablet Android 2. 4 Gb...
Unable to connect to the internet ... error code 52130
This error is caused by a wireless router firewall issue. If your wifi network has a password, you need to input it while trying to connect your wii. Or you can just disable the password of your wifi.
Jul 18, 2011 | Nintendo Wii Console
I cant open my wifi connection model m1110
try to refresh your wifi..
then in your pc,
at your control panel find the network connections
then look for the wifi connectivity if it is connected or enable.
enable it if you found disabled.
check your device if the lit green is on and stable in internet..
if it is so then check your pc..
be sure your wifi password is correct..
Jun 27, 2011 | Computers & Internet
After changing the sucurity password on belking router I'm not able to connect to internet with laptop. Should I make changes to laptop as well or what should I do? When I switch back to the old password...
first tell me whats your security type if its wpa -> try changing with 64 bit wep make up 10 digit numbers.. once you do this click under wireless ->channel ssid & change the ssid & disabled wifi protected set up
Aug 04, 2010 | Belkin (F5D7230-4) Router (587009)
I use Thomson ST585 v6 which automatically connects my desktop, but do not know password to allow visitors to connect their laptops, can I retrieve this, or can they connect if I press the black button on...
The black button on the front panel of 585's is to enable / disable the wireless network (WiFi). If the WiFi is enabled with a password setting the led on the front panel is green, if the WiFi is enabled without a password setting (free to all) the led is red. If your desktop is connected with a cable at 585, you can just use the button in order to enable (or disable) the WiFi for the visitors. If you want something more secure you can set the WiFi with a password but in this case you must tell your visitors the password in order to acess the WiFi. It's up on you to decide the way you want to use the WiFi. Of course if you need help to set up the WiFi password post me a reply.
In case of a problem or clarification, don't hesitate to post me a reply also.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 10, 2010 | Computers & Internet
TP-LINK Tenda W311R WirelessN Router AP 4port Switch 150Mbps Logo
161 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
