Question about TDV Vison F173 17" Flat Panel LCD Monitor
My desplay is 90 degrees roteted
How do i bring it back to normal?
  • erbel84 Jan 26, 2009
    I have a E773c Dell monitor
    the desplay on my monitor just turned 90 degrees ' how can i rotate it back?
    tryed the menu botton
    We tried to rotate it back with the rotation icon but it wouldn't do anything. We restarted it and the Dell info came up correctly, but then the desktop icons came up the same way - 90 degree turned.
  • 15,935 Answers
Usually it is a combination of 2 keys.
CTRL + up or down arrow key.
Try that. If it does not work, re-post.
Thanks for using FixYz - a FixYa rating is appreciated!!
Posted on Jan 26, 2009
Mariva 1.4. Why does temperature gauge reading fluctuate?
check grill and radiator fins are not plugged and fan is not damaged and is working.
sounds like a thermostat or water pump issue.
Jan 09, 2016 | Vauxhall Cars & Trucks
Display on laptop screen
You may have inadvertently pressed the correct hot keys to change the display around. In the bottom right hand corner of the screen you may have an icon for your graphics. If you click, or right click you can get the properties up. You should be looking for something which refers to screen orientation ie from landscape to portrait or vice versa.
Feb 11, 2008 | Acer TravelMate 2300 Notebook
What is a normal temperature for my 2003 pontiac sunfire. is 90 too high
It should fall between 200 and 250 degrees F, I take it when you say 90, that means 90 degrees Celsius, that equates to 194 degrees F.
You are within range, actually running little bit cooler, which is GREAT!
Dec 09, 2013 | 2003 Pontiac Sunfire
The monitor picture has moved 90 degrees
Right click on the monitor display away from icons ans on the desktop. Scroll down to either properties or if it says ATI or Nvidia control panel. If it is under properties look for the txt "Orientation", click on "Landscape" or "0" degrees whichever it states. Click apply and OK. If you bring up the control panel for display settings, then look in the left hand pane for "screen Orientation" and again choose "Landscape" or "0" degrees....whichever one it states.
Jul 01, 2010 | Dell 0Y3740 Keyboard
Possible anti freeze leaks , it exceeds to 90 degrees on the thermometer
what exceeds to 90 degrees?
The normal coolant temp will be over 190 degrees just from the thermostat in the engines,it will kick the cooling fans on at 210 degrees,
Nov 18, 2009 | 2005 Pontiac Vibe
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
Jetta 2003 TDI
My mechanic in our town did a quick computer check. Car computer indicated a low level of antifreeze, he topped it up, cleared all messages off the car computer and said to watch the the heat guage for any further irregularities. I'll keep an eye on it, love the car, great mileage fun to drive.
Nov 05, 2008 | 2002 Volkswagen Jetta TDI
Display on the screen/monitor
im not sure if this will help but if your video card have its own control panel try going there and try looking for Rotate Display or something close to it. Im using Nvidia 6200LE and it has the option to rotate 90 and 180 degrees..you might want to try it
Nov 28, 2007 | Samsung SyncMaster 740N 17" LCD Monitor
Display flips 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Jan 26, 2007 | LG Flatron 775FT 17" CRT Monitor
TDV Vison F173 17" Flat Panel LCD Monitor Logo
Top TDV Vison Computers & Internet Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Are you a TDV Vison Computer and Internet Expert? Answer questions, earn points and help others
