Question about Dryers
Dryer runs as long as you hold switch
My dryer runs fine sometimes. However sometimes it will not run unless you hold the start switch down, even then however it will stop running after a few seconds of holding the switch down. The timer runs the door is shut good but i do not know what i can do to fix it?
  • 130 Answers
You already know whats wrong. the switch is starting to go bad. replace and all should be back to the norm.
Posted on Jan 26, 2009
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Wont Run unless hold start switch
You most likely have a faulty motor centrifugal switch. This switch is engaged when the motor starts rotating. The switch itself could be faulty or the inertia-mechanism that activates the switch could be faulty. The inertia-mechanism usually has two small springs that pull it back into its resting position when the motor stops turning. I have found that the springs will sometimes break and produce the symptom you have described.
Below is a diagram of common centrifugal switches. The switch will be mounted on the end of the motor.
Jun 21, 2010 | Kenmore 63932 Electric Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Kenmore Elite Dryer only runs if hold Start Switch
sound more like a control board failure // if it has one,, maybe the belt, starting switch
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer won't run unless we hold the button
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, good for another 10years
Aug 08, 2008 | Kenmore 63942 Dryer
Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Sep 21, 2007 | Dryers
Dryers Logo
133 people viewed this question
Top Dryers Experts
