Question about Haier Refrigerators
MY HAIER 1.7 FRIDGE FREEZES ONLY
FRIDGE DOES NOT SHUT DOWN WHEN IN OFF POSITION, CONTINUES TO FREEZE UNTIL UNPLUGGED
My trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
Posted on Feb 15, 2013
TheMobilian
  • 8220 Answers
SOURCE: I just bought a used
Probably low on gas.
Posted on Jan 02, 2009
  • 52 Answers
SOURCE: M Haier refrigerator, model HSE12WNAWW, is getting
Seems like you set it at the lowest as you mentioned, try the recommended setting. The lowest is the coldest, that will freeze up your food items.
Posted on Feb 06, 2010
  • 35 Answers
SOURCE: have a samsung model rb2155sh fridge/freezer that
BAD PC BOARD REPLACE
Posted on Apr 07, 2010
heatman101
  • 43501 Answers
SOURCE: My fridge side is too
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Jan 22, 2011
oldTech2332
  • 2341 Answers
SOURCE: Freezer coil, inside freezer compartment continues
As you already know that is a failure of one of the defrost system componenets. This tip i wrote covers the components of the defrost system and how to check them.
http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Posted on Sep 10, 2011
Will not turn off. Thermostat control clicks but refrigerator continues to run in the off position and therefore will freeze everything inside.
Check for a small wire sometimes copper color that ends in a small bulb in the refrigerator. Then check to make sure this sensor is not unplugged from its source. This if the thermal sensor that measures temp in the refrig
Nov 04, 2013 | Haier HSA04WNCWW 3.9 Cu. Ft....
Erorr code -Err 1 is showing on our machine. Any ideas? Thanks.
Is this a Haier Washing Machine?
'coz I found an answer on their site..
"Q. The display shows Err 1. A. The door is open or not properly locked shut. Open and close the door, or firmly push the door shut until you hear a 'click'. If the problem continues, call the customer help desk or an approved service engineer."
Src: http://www.haier-uk.co.uk/support/faq
Hope this helps.. :)
Jun 09, 2011 | Washing Machines
Haier frig., model HNSE05, continues to cool till all contents are frozen. Can not reduce temperature to aceptable levels.
Hi,there
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help out....
May 07, 2011 | Haier Refrigerators
Fridge keeps over freezing
Hi, the only reason the unit will over freeze is if the thermostat control is faulty and the unit is running all of the time. You can turn it up or down to see if it responds and shuts off. If it continues to freeze, replace it. If you can get it to shut off, open the door and watch it to see how long it takes to come back on. It shouldn't take to long to respond to the warmer ambient temperature. If it does cycle on and off, I would replace it as it could not be accurate. Keep me posted.
Shastalaker7
Apr 01, 2010 | Haier HSB03 Compact Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
Refrigerators Logo
112 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
