Question about Dell Dimension 2400 PC Desktop
Have used dell dimension 2400 hard drive died replaced it now it only goes to boot device menu or black screen with blinking cursor
I don't have original start up disc with os. Can I use windows vista, or try to find a replacement copy.
    Problem Solver:
  • 32 Answers
You will a full blown version of whatever software you want to install. Also try using the F8 key during bootup. See if the computer will boot up into Safe Mode. You should be able to made System restore disks from there if it will get that far.
Posted on Apr 11, 2014
PaTcH1313
  • 19 Answers
SOURCE: System cannot boot
huh that is odd, you might want to try f8ing the start up and running "Last know good configuration that worked" or you could try booting it in safe mode. You also might try reformating the drive you installed the updates too. Another thing that can cuase it is your RAM you might try booting with only one stick of RAM in. Try thoughs and let me know what you found out
Posted on Jan 12, 2008
rwalkero
  • 82 Answers
SOURCE: Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Posted on Feb 19, 2009
crapiemael
  • 241 Answers
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
  • 156 Answers
SOURCE: My Dell Dimension 4600 needs to be reformatted.
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Posted on Jul 16, 2009
jaye_ellen
  • 591 Answers
SOURCE: Having Trouble Reinstalling XP on my Dell Dimension 3000
Is the "New" HD in the system presently? If not install it. Boot from the original XP Restore disk (CD/DVD). When you get Windows going (from CD) go to COMPUTER and format your C: drive. Once this is done go ahead and run the Restore from the original XP disk. All other files (the **** you mentioned) will be gone, once and for all.
Posted on Sep 22, 2009
Dell Dimension 2400 runnning windows XP will not boot up
there are several issues and there are several solutions for this problem. I need you to please be more specific. Usually when a computer doesn't boot up, it goes to the initial black screen and usually it will display a message by the top left of screen where cursor is blinking. Please tell me whet that says, and I will tell you exactly how to fix the problem.
May 20, 2014 | Dell Computers & Internet
Have a used dell dimension 2400, hard drive died i replaced it, but i dont have the original os disc that came with the system, can i use my copy of vista, or find another copy
If your Dell computer had Vista installed then you can use your copy of Vista CD and you can use the product installation code that is printed on the Windows label that is attached to your Dell.
When you insert the Windows CD into your Dell and boot up your computer then select the CD as the boot device (ie 4=IDE CD).
After Windows is installed and activated then you need to install the Dell computer's device drivers.
You can download the device drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 21, 2013 | Dell Dimension 2400 PC Desktop
When I push the power button, the main dell start up screen comes on followed by a black screen with a blinking cursor in the upper left corner. It uses Windows 7
Remove any CD's or USB drives 1st.
Sound like its trying to load and can't find hard drive, CD, or USB device. You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key to press during boot. Make internal hard drive first. Save and restart. Reseat hard drive if it does not show up in BIOS.
Oct 05, 2012 | Dell Inspiron 560 PC Desktop
Computer does not boot up
if you can be more specific about the problem, maybe we can help you out.... is the psu fan turning? what about the led in front of your case? or they're working just fine but the lcd didn't display anything? or there's only the cursor blinking in the screen?
try to get inside the bios setup by pressing f2 or del button.. check your hard drive... is it detected by your board... go to the boot order, make your hard drive as your first/primary boot order... then save by pressing f10. if you still having the problem, re install the window.... hope this will help
Jun 17, 2012 | Dell Dimension 2400 PC Desktop
Can i make a bootile usb for dell dimision 2400
If the BIOS setting for the Boot up device order does not have the USB as a boot up device then it is not possible to boot up your computer with an USB device.
For a Drive 0 seek problem -
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 19, 2012 | Dell Dimension 2400 PC Desktop
Dell Dimension 4300 desktop screen goes black after windows splash screen appears. Have reseated RAM.
After hitting the power button on your computer, throw it into "BOOT MODE" and select your hard drive. See if this helps your computer load. If so, you will have to go into your BIOS Setup and make your current hard drive your Primary Boot Device.
If this doesn't help, load your restore disc and check your drive for errors.
Your problem shouldn't be anything more than a few registry errors OR a boot problem.
Sep 09, 2011 | Dell Dimension 4300 PC Desktop
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
System cannot boot
Jan 12, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
