Hello, I have had a Sears Kenore Elite Oasis top-loading washer, model 110.2803, for 2 years. I used to be quiet during spin cycle, but has gotten gradually louder and now is very loud. What can I d
Loud when in spin cycle
  • Washing Mach... Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 21, 2013
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: Kenore Elite Oasis top loading washer wont spin
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Posted on Sep 23, 2011
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Noisy during spin cycle. REAL NOISY $400.00 to repair? First a computer recall ang now a $400.00 repair. Bearing and seal kit. Can this be done with common tools and some mechanical skills?
The following may or may not answer your question, but following is the Whirlpool Service Manual for their Cabrio washer (basically the same as the Sears Oasis)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
This should give you an idea as to whether you can repair it yourself.
Apr 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Excessive noise during the spin cycle. we have owned the washer for 16 months. problem started 1 wk. the machine is level.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis HE elite washer Sounds like coins rattling occasionally during spin cycle.
there are coins or small items in the pump. We used a wet dry vacumn to clean it out thru the drain hose.
Oct 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
