Question about Whirlpool Washing Machines
Water is coming out the spot you put soap in
Duet sport
  • Whirlpool Master
  • 17,130 Answers
Click this link: detergent tray
Posted on Jan 21, 2013
3 Suggested Answers
  • 240 Answers
SOURCE: water leaking from the soap dispenser during rinse and spin cycle
use liquid instead of powder and always use HE detergent
Posted on Apr 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool duet sport that is overflowing
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Water is coming out the front were you put soap in
Check for a possible clog that would cause the water to shoot out. It very well could have something blocking it or just a build up of soap. I hope this helps you. Thank you for using FixYa.
Jan 05, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet is overflowing from the soap drawer at the beginning of the cycle
That is VERY unlikely, the gasket can not be seen from the inside view without removing the soap dispenser. It may be an oring or gasket. Do you have a hard water situation there? Otherwise, I would check with the manufacturer and see if there was a recall on this particular model number. The most obvious and silly solution is to check that there is no obstrution in the path of the water wand.
Jan 15, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Water is overflowing from the soap dispenser as if the intake has an object in the filter before the wash basket.
i would say you are spot on,some times soap can build up over time and block the dispensertry cleaning it with warm clear water.adrian;;;;
Dec 03, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Water over flowing in soap dispencer Whirlpool sport duet washer
A sock was in between the two tubs blocking the water going tnto the main tub. This caused the water to backup and overflow in the soap dispencer..and all over the floor I then put my hand in between the two tubs and pulled the sock out. Thanks to the expert group for giving me this solution.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet sport
if its new top loader needs water temp switch need more infor "less soap plz"
Nov 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Softener slot won't drain.
take the soap draw out there should b a sign on the draw to press also the top of the sofner compartment comes off u will see a hole where the water goes make sure it is clear put the lid back on hold soap tray under water tap let the water fill the sofner compartment it shoud run out
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
