Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Reverse door handle on kenmore refrigerator model 795.75014402
gr82fly
  • 3 Answers
SOURCE: Removing refrigerator door handles
You might try checking to see if the screw head is actually on the handle, but hidden by the handles cover. Look at the side and see if you notice a seam. This can be pried open and the screw head will be seen.
Posted on Feb 23, 2009
  • 212 Answers
SOURCE: Replace Refrigerator Handle
should have screw covers to remove. then remove screws. cover are at top and bottom of handle. push up at top one and down at bottom.
Posted on Jun 21, 2009
  • 89 Answers
SOURCE: I have a Kenmore Over under refrigerator model #69872
you can purchase a new seal
Posted on Jul 10, 2009
  • 11 Answers
SOURCE: On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Posted on Sep 06, 2009
aasc
  • 1606 Answers
SOURCE: I need to take the handles off on my kenmore side
Try sliding them upwards ( the top ones ) , downwards ( for the bottom ones ) , as far as they will slide , then remove .
Posted on Nov 13, 2009
How do you reverse door handles on Model 596.70002002
You are going to need a tech to do this.
Dec 03, 2016 | Refrigerators
How do you reverse the door on a kenmore cold spot 106?
Take door off, reverse the handle and hinges to other side of door and reinstall.
Mar 04, 2016 | Kenmore Refrigerators
Can I reverse the door on a kenmore 253.6580250A
Remove doors starting from the top, reverse handles, and hinges starting from the bottom. Owners manual should show you how
Mar 04, 2014 | Kenmore Refrigerators
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Want to reverse door handles
On most you take the top hindge off. Lift the door off the bottom one then remove the bottom hindge.
May 09, 2009 | Refrigerators
Feb 23, 2009 | Kenmore Refrigerators
Door handle is loose
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
Feb 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
