Question about Emerson Refrigerators
Motion activated candy dispenser will not work
M&ms will not distribute them
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
The motion sensor is a glass eye, make sure the eye is clean, if cleaning does not fix the problem then the motion sensor may need replacing.
Posted on Jan 21, 2013
Tip
Check for DOS, Check to see if you are infected...
When you first turn on your computer (BEFORE DIALING INTO YOUR ISP), open a MS-DOS Prompt windows (start/programs MS-DOS Prompt).
Then type netstat -arn and press the Enter key.
Your screen should display the following (without the dotted lines which I added for clarification).
Active Routes:
Network Address Netmask Gateway Address Interface Metric
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
255.255.255.255 255.255.255.255 255.255.255.255 0.0.0.0 1
Route Table
Active Connections
Proto Local Address Foreign Address State
If you see anything else, there might be a problem (more on that later). Now dial into your ISP, once you are connected; go back to the MS-DOS Prompt and run the same command as before netstat -arn, this time it will look similar to the following (without dotted lines).
Active Routes:
0.0.0.0 0.0.0.0 216.1.104.70 216.1.104.70 1
216.1.104.0 255.255.255.0 216.1.104.70 216.1.104.70 1
216.1.104.70 255.255.255.255 127.0.0.1 127.0.0.1 1
216.1.104.255 255.255.255.255 216.1.104.70 216.1.104.70 1
224.0.0.0 224.0.0.0 216.1.104.70 216.1.104.70 1
255.255.255.255 255.255.255.255 216.1.104.70 216.1.104.70 1
Route Table
Active Connections
TCP 0.0.0.0:0 0.0.0.0:0 LISTENING
TCP 216.1.104.70:137 0.0.0.0:0 LISTENING
TCP 216.1.104.70:138 0.0.0.0:0 LISTENING
TCP 216.1.104.70:139 0.0.0.0:0 LISTENING
UDP 216.1.104.70:137 *:*
What you are seeing in the first section (Active Routes) under the heading of Network Address are some additional lines. The only ones that should be there are ones belonging to your ISP (more on that later). In the second section (Route Table) under Local Address you are seeing the IP address that your ISP assigned you (in this example 216.1.104.70).
The numbers are divided into four dot notations, the first three should be the same for both sets, while in this case the .70 is the unique number assigned for THIS session. Next time you dial in that number will more than likely be different.
To make sure that the first three notation are as they should be, we will run one more command from the MS-DOS windows.
From the MS-DOS Prompt type tracert/www.yourispwebsite.com or .net or whatever it ends in. Following is an example of the output you should see.
Tracing route to /www.motion.net [207.239.117.112]over a maximum of 30 hops:
1 128 ms 2084 ms 102 ms chat-port.motion.net [216.1.104.4]
2 115 ms 188 ms 117 ms chat-core.motion.net [216.1.104.1]
3 108 ms 116 ms 119 ms www.motion.net [207.239.117.112]
Trace complete.
You will see that on lines with the 1 and 2 the first three notations of the address match with that we saw above, which is a good thing. If it does not, then some further investigation is needed.
If everything matches like above, you can almost breath easier. Another thing which you should check is programs launched during startup. To find these, Click start/programs/startup look at what shows up. You should be ableto recognize everything there, if not, once again more investigation is needed.
Now just because everything reported out like we expected (and demonstrated above) we still are not out of the woods. How is this so, you ask? Do you Netmeeting? Do you get on IRC (Internet Relay Chat)? Or any other program that makes use of the Internet. Have you every received an email with an attachment that ended in .exe? The list goes on and on, basically anything that you run could have become infected with a trojan. What this means, is the program appears to do what you expect, but also does just a little more. This little more could be blasting ebay.com or one of the other sites that CNNline was talking about.
What can you do? Well some anti-virus software will detect some trojans. Another (tedious) this is to start each of these "extra" Internet programs one at a time and go through the last two steps above, looking at the routes and connection the program uses. However, the tricky part willbe figuring out where to tracert to in order to find out if the addresses you see in step 2 are "safe" or not. I should forewarn you, that running tracert after tracert, after tracert might be considered "improper" by your ISP. The steps outlined above may not work exactly as I have stated depending upon your ISP, but wuth a true ISP it should work. Finally, this advise comes with NO warrante and by following my "hints" you implicitly release me from ANY and ALL liability which you may incur.
Other options
Display protocol statistics and current TCP/IP network connections.
Netstat [-a] [-e] [-n] [-s] [-p proto] [-r] [intervals]
-a.. Display all connections and listening ports.
-e.. Display Ethernet statistics. This may be combined with the -s option.
-n.. Diplays address and port numbers in the numerical form.
-p proto..Shows connections for the protocol specified by proto; proto may be
TCP or UDP. If used with the -s option to display per-protocol statistics,
proto may be TCP, UDP, of IP.
-r.. Display the routing table.
-s.. Display per-protocol statistics. By default, statistics are shown for TCP
UDP and IP; the -p option may be used to specify a subset of the default
interval..Redisplay selected statistics, pausing intervals seconds between each
display. If omitted. netstat will print the current configuration information
once
on Jan 25, 2010 | Computers & Internet
Sensor doesn't work
Unfortunately, there is nothing you can do to fix this on your own. The best solution is to contact the manufacturer. Even if the item is not under warranty, if they have good customer service, they should replace it for you free of charge.
Jan 31, 2013 | Brookstone SnackMan Motion-Activated Treat...
Kenmore w/GSI 23 Ice maker: door is distributing crushed ice in both the cube & crushed mode. Is there a reset function to get the cube mode to begin working again when that button is selected? thx,
it sounds like the mechanizme is jamed, (if it has one) remove the ice tray bucket and where the metal rod sticks out the back of the bucket see that where it goes into the fridge is not frosted up, hold the freezer door light button in and activate the ice dispenser watch to see if a solinoid activates a latch if it does not move free it up so that it can move freely up and down... (if this is your model)
Aug 22, 2011 | Kenmore Side by Side Refrigerator
Lost the instructions to Elmers Sour Candy Activity Kit.. I need to know where I can get the instructions.
Not sure you still need the instructions ha. I was looking for them myself & came across your post. I finally found them after searching a bit. Here's the link, scroll down to where you see instructions & click on it Sour Candy Kit Fun Science Kits for Kids by Scientific Explorer
Feb 20, 2011 | Scientific Explorer Elmers Education Sour...
My candy cna 145 will not let water into drum. all just floods out of soap dispenser
It sounds as though there is a soap powder blockage in the dispenser or the dispenser hose in to the drum.
Try pushing into the hose with something to clear the blockage.
Please rate my solution.
Jan 23, 2010 | Candy Washing Machines
Refrigerator in-door water dispenser fails to work
First ... your model number is missing some on the end. please check your model number on the machine for the correct lookup of parts.
For your situation I found this model number # FRS22ZRHD1. Take a look at this picture of this models dispensor.
there are 3 switches # QT 2 -- 38a & 38b
this should be close to your model of fridge but you will half to make sure.
and yes you should just replace the bad switch.
Part numbers for the switches for this model # are 218479900 & 241689101
Jan 08, 2010 | Refrigerators
Motions don't stay active when doors and windows are on too.
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
Jul 12, 2009 | GE Security Simon 3 Wireless Home Security...
Candy
is the tablet released from the dispenser? if not the solenoid in the unit has gone and the dispenser unit will need replacing.
Jun 06, 2007 | Candy 24 in. CD950 Free-standing...
Refrigerators Logo
312 people viewed this question
Top Emerson Refrigerators Experts
John Tripp
John Tripp
mike cooper
Johnny 1000
Level 1 Expert
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
