Question about Rocketfish Srs Wow Wireless Gaming Headset W/3d Surround For Xbox 360,ps3,pc,mac
Ricketfish srs wow - mic is not working
Everything stopped working. The axillary cord went out, I replaced that, however the mic isn't working now.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 118 Answers
  • Press the PWR button on the wireless receiver to turn the unit on. The headset has a sleep/standby mode feature to preserve battery life. The unit goes into sleep mode if there's no input for 3 minutes.
  • Twist the tip of the microphone so the sound holes face your mouth.
  • Position the microphone several inches away from your mouth so it does not overload when you speak. Try to balance the microphone position and the volume setting for optimum voice level.
  • Press the ALL MUTE button (the Rocketfish logo) on the left side of the headset once to make sure that the All Mute function is not activated. The LED on the wireless receiver will light red when All Mute is activated.
  • Make sure that the volume on the wireless receiver is not turned down or muted. The LED on the wireless receiver will light orange when Mute is activated.
  • Rotate the CHAT VOLUME dial on the wireless receiver to control the chat volume.
  • Make sure the USB cable is connected to both the wireless transmitter and your device.
  • Make sure that all connections are correct and secure. Sometimes a cable may appear to be connected but it may not be pressed in all the way.
  • Make sure that the wireless receiver batteries are installed correctly. See Question 19.
  • Make sure that the wireless receiver batteries do not need replacing.
  • Make sure that the microphone isn't plugged into the Line In port (or vice versa).
  • Make sure the headphone jack is pushed all the way into the port.
  • If you're using an Xbox 360
    • Make sure the wireless receiver is connected to the Xbox 360 controller using the supplied chat cable. On the wireless receiver, press firmly, so no part of the silver jack is showing. This tight connection helps to make sure the cable does not fall out during gaming.
    • Try a different Xbox controller.
    • Try recording a message to a friend by selecting My Friends, Send a Message, then Add Voice. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
  • Try testing the microphone by connecting the headset to a smart phone and make a test call or record a memo. If you can hear yourself, the chat problem could be a game issue, a problem on the recipients end, or some other variable not related to the headset.
If these steps don't work, then I would advise seeking replacement.
Posted on Nov 08, 2013
Unlock srs wow hd
how to unlock htc srs wow hd windows phone
Apr 23, 2013 | Cell Phones
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
The passenger side window and rear windows will not work is there a fuse for the lockout switch
No, there isn't a separate fuse. If the driver's master control works and the lockout is disabled - then chances are that the master control switch needs to be replaced. All of the axillary switches run through the driver's master switch.
May 27, 2011 | 2001 Kia Optima
Just bought a Jeep with this radio in it -- I am trying to access my phone's downloaded songs - not through a USB, but through an axillary cord plugged in to the back -- I find where I can change to...
If it is on the phone then you just plug it in the headphone jack. if it is on the radio then you just plug it in the aux port on the radio. it should automatically detect the cable.
May 15, 2011 | Car Audio & Video
I have a Midland CB Car with no mike or a car power pluge, the model # is 70 - 336B and the serial # is 760408
Your midland CB will use a standard 4 pin wired CB plug which is most common for most mics sold today. Your power cord will be a standard 3 pin CB power cord which again is most common with CB's today. You need not purchase a "radio specific" cord or mic. Cobra, Uniden, Midland all the same mic pin out and power cords. Good luck.
Feb 09, 2011 | Radio Communications
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
I have an 2001 Honda Accord, SRS went off a few
That is usually the case. That is to inform you of a malfunction with that particular part of your vehicle.
Oct 06, 2009 | 2001 Honda Accord
Rocketfish Srs Wow Wireless Gaming Headset W/3d Surround For Xbox 360,ps3,pc,mac Logo
167 people viewed this question
Top Rocketfish Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Rocketfish Radio Communication Expert? Answer questions, earn points and help others
