Question about Gateway Computers & Internet
Laptop wont power up power button blinks 5 times when pressed
Nv52l06u
  • 84 Answers
The first thing i would do is to take it apart but i repair laptops here is what you can do on the back you should see a little keyboard pic next to a screw there maybe 1 to 3 of them with that pic unscrew them (if you feel ok about doing that) after taking out the keyboard screws there is a little disk pic near the keyboard unscrew cd screw take that out gently with computer off and not in hibernation look at cd drive open cd drive with a paper clip straighted out to poke into a itt hole on cd drive look a the eye reader on the cd tray make sure its not burnt also get a flash light and look inside the empty cd drive bay see if you see anything and smell inside the bay ok back to taking out the screws take the battery out underneath there are 2 rows of screws (ok only do this if you feel ok about it this process takes me 5 minutes )after taking out the screws turn unit over hold on to monitor as it is loose now lean it up against a wall or somthing now you need to pop off the button bar gently its on there good set that where it does not pull the cable unscrew thr row of screws you see keyboard will come up and lay it down not to pull cable out and look and smell maybe even blow it off with some air not to much pressure hold your breath as there will be dust now look for any thing that looks like it was grounded out look carefully if you dont see anything or smell any thing well the next step is a repair guy check that cd player carefully and where it connects inside with flash light looking for darkness color smell the cd drive connector on the back might be a short which requires taking it apart i see alot of those not ruling out a bad video card integrated im able to do this you are in auburn im next town north i charge half to repair because i want everyone to have a good running system that does not break the bank i repair laptop not to make money i do it because its fun for me let me know
Posted on Mar 04, 2013
  • 408 Answers
SOURCE: Laptop will not boot
ok, take the battery out and leave it unplugged for a few hours.  Only plug the ac adapter in after.  Press and hold the power button for 10 seconds.  Does it still do it?  If it does work, then chances are your mobo has bit the dust or you have knocked loose an internal charging part.
Posted on Mar 09, 2009
micromend
  • 748 Answers
SOURCE: Laptop won't start
You didn't mention the brand? First, take out the battery and plug in the AC adapter. Does it boot?
Leave the battery out of the computer a couple of hours, now put it back in and connect the AC adapter. Does it boot? If you still get nothing the computer needs to see a reputable repair person.
Posted on Apr 04, 2009
SOURCE: problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Posted on Oct 01, 2008
  • 11 Answers
SOURCE: HP Laptop DV2415NR Need to power on twice to boot.
log in your bois and make sure first boot option is hard drive. not cd/usb or anything else. unless you need to
Posted on May 24, 2009
  • 1019 Answers
SOURCE: red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Posted on Jun 12, 2009
HP 2000-410US when turned on the power light button blinks 1 time every 5 seconds, nothing elas
1. Disconnect anything that is connected to your laptop. Usb Flash discs, External HDDs, Wireless Devices using dongles etc.
2. Make sure that your device does not receive any power i.e. Disconnect your ac cable, and remove battery from your laptop.
3. Hold down the power button for 5 seconds. This would drain remaining power from your laptop. But as the power cable and the battery are disconnected, you should not expect anything to happen.
4. Identify where your RAM is located under your laptop. Unscrew the cover off, then remove the RAM from your laptop. Replace the cover temporarily.
5. Flip over your laptop. Connect your power cable to the laptop, NOT THE BATTERY NEH! Then press the power button. Sometimes your laptop will make long beeps to let you know the RAM is not inserted in your laptop. But nothing will happen on your monitor because it needs RAM to show you something.
6. After those beeps, remove the power cable. Press the Power Button to drain remaining power on your laptop. Flip the Laptop and replace the RAM you have removed earlier.
7. Insert your power cable and try restarting your laptop and see what happens. I am sure by now you should have some response on your laptop monitor.
NB: While performing the above mentioned, remember PC or Laptop parts are delicate. Even static electricity can damage them. Thus before handling your laptop components, make sure you touch the wall or any large metal subject from time to time to discharge the static. Wear 100% cotton cloths as you are working on it. Bare feet even better to discharge the static
Jun 14, 2014 | Gateway MX8711 Notebook
I pushed a button on my NV52L06u and it went from genuine to not genuine how can I fix this?
download REMOVE.WAT version2.2.5
and install to your laptop
after installing the laptop request for restart just restart
after that the genuine is gone.
and go to updates. check the do not updates
find never updates.
and then back your nice background ::))
thnx
Nov 26, 2013 | Gateway NV52L06u Laptop PC
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How do I take out the over flow cartrigde on a mp130? Printer wont print it says i need to empty my over flow and I don't know how.
SAome have a pad some have a small tray. This cancelled the warning and reset the printer for use.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma ip90 bought August 06:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Dec 18, 2009 | Computers & Internet
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
When I turn the printer power on, The lights are blinking.
  • Unplug Power Cord
  • Hold POWER and RESUME buttons
  • Plug in Power Cord
  • Release buttons after the printers starts up
  • Hold CARTRIDGE and RESUME
  • Press POWER
  • Release all buttons after the beeps
  • Press CARTRIDGE 16 times
  • Press RESUME
  • Unplug the Power cord
  • FINISH
  • Nov 12, 2009 | Canon BJC 55 InkJet Printer
    Canon pixma mp-610
    Try resetting the printer:
    Jul 19, 2009 | Office Equipment & Supplies
    Pixma ip 3000 power on all the time no functions. cannon
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
    Problem with laptop- no power
    Sep 04, 2008 | Toshiba Satellite A105 Notebook
    Computers & Internet Logo
    163 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
