Question about Mtd 22" Yard Machine Push Mower
Lawn push mover - Mtd 22" Yard Machine Push Mower
STARTING PROBLEMS ?? For a gas engine to start basically you need two things..fuel delivery and good spark....remove the spark plug ...Is it wet with gas??IF YES good you have fuel going into the cylinder.BUTwhat about spark?..Put the plug back in Pull the plug wire use a wooden closepin to hold the wire real close to the top of the sparkplug and have someone pull thr cord you should see little sparks jumping from the metal connector on the end of the plug wire to the sparkplug if you have spark.. if you have both fuel and spark maybe you have bad gas??You could try shooting a little starting fluid[ether] into the sparkplug hole screw the plug back in and try starting again..Goodluck RW...
Posted on Jan 21, 2013
Toro push mover starts then quits
Looks like a fuel problem. Remove fuel line from carb., should get fuel.
Nov 25, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
The rear wheel drive in my Husqavarna push lawn mover quite working, how can I fix it?
You can try putting a little more tension on the drive belt. It is probably stretched out a bit and the drive engagement cant cancel all the slack out. So, the belt slips.
Pull out your owners manual and look up instructions for tightening the drive belt. If you dont have a manual go to the Husqvarna website and get a PDF copy.
Good luck and be careful!
Jul 20, 2010 | Husqvarna 675 hp 21" Honda Rear Bag Push...
Toro 6.5HP lawn mover it starts the it stops.
CHECK FOR WATER. DRAIN TANK AND REFILL MAY HAVE TO DRAIN CARB
Sep 24, 2009 | Toro Lawn Mower With Toro Power Tools
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
Lawn mover - self propelled does not work - need to manually push
Take it to a shop. one of your safety switches is most likely defective.
Apr 27, 2009 | Echo Garden
Broken starter cord MTD Model 125-478R062
try this link.
http://www.smallenginesuppliers.com/shop/html/broken_starter_rope.html
you will want use size #4 or 4.5 starter rope. about 7 foot in length.
Mar 17, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
27 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
