How do I fix my color for the tv via the menu board there is no default button.
    Sergeant:
  • 211 Answers
You usually can't go wrong by starting with all the settings set to a mid range, then adjust from there. From your video it seems as if it has been adjusted already very few TV's are set to the lowest settings. There are also "presets" that can be chosen I.e. " warm" or " cool" settings that maybe to your taste. (those choices will preset everything, I like the " warm" setting for my tastes.)
Posted on Jan 21, 2013
Osd is saying the main menu is locked how do i unlock
Win Tyler,
Information on resolving your locked screen on your LCD is listed below.
In the TV Menu Settings menu you can
select TV Button lock to lock the TV
Menu and the side panel buttons. When
this option is enabled, only the power
button functions. To unlock the TV Menu
and side panel buttons:
1. Press the Menu button on the TV. A message appears stating that the TV is locked
2. While the message is on the TV, press the channel up and volume increase button
simultaneously.
If you are using the DVI connector, you may need to verify the following settings:
Source - The default setting is Auto. The T V automatically detects if a computer (PC) or video
device is being used. If the image does not display correctly, you can select the source, PC or
Video, depending on the device you are using.
Color - The default color space is RGB. If the colors are not displaying correctly, you can change
the setting to YUV.
You can download and view the online users manual from the link below.
Manuals & documentation for your LCD TV W2306C
Product Support
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 18, 2015 | Dell W2306C 23 in. HD-Ready LCD Television
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
RU49NZ23 RED GREEN AND BLUE IN 3 D AND DID AUTO CONVERGE BUT NOW THERE IS SOUND BUT NO PICTURE
follow this steps and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 31, 2013 | LG RU-60SZ30 60" Rear Projection...
Recently(within the past 6 months...) have been having a problem with my L37HDTV10A. The picture always takes a yellow hue. This applies to every input accross the board, and changing hue and color...
Hi.
A digital TV handles the color in three channels, red green and blue. Your TV has a problem on the red channel. That causes pictures getting yellowish. The computer functions can compensate the fault, but that is not a solution. If the problem happens on every input and also with internal tuner, then the logic circuits that elaborate video signal are defective. The main board is usually replaced to fix the problem. Before replacing the main digital board the technician can check if any repairable fault is found. A contact in one of the input for example may short the circuit affecting one of the color channels. In that case the tech will only need to resolder the connector on board to fix the problem. More commonly the whole board must be replaced.
Here parts for this TV: L37 TV Parts ' ShopJimmy
Regards.
Ginko
Sep 19, 2011 | Vizio L37 Television
My kids changed the color on my 61 inch RCA and now i cant get it back to normal. Everything thats suppose to be purple is brown and pinks are orange and yellows are pale. Everything else is ok a little...
Someone probably played around with the "Tint" settings in the TV menu. The easiest way to fix it is to go into the TV picture menu and reset everything to the default settings. There's probably one option for "Reset to Factory Default" or something along those lines. Since every TV is different with this, you should read your owner's manual to find how to enter the menu and find the reset button.
May 04, 2011 | Televison & Video
Vizio worked fine yesterday. today get "unable to launch com.yahoo.widgets.tv.container" when pushing the VIA button
Funny, same thing happened to me about the same time! Took me a while to figure out how to fix it. You have to get to the HDTV Settings menu and hit the Help icon. Do a Clear Memory/(Factory Default) and go thru that process, basically you go through all the settings just as you did the first time you powered up the TV. This will fix your problem.
The challnge is...how to get to the HDTV Settings menu when your VIA button only brings up the error you described? I finally got there like this: Hit the "Input" button on the remote, navigate to "TV" and hit OK (basically just select TV as your input), hit the Menu button on the remote and that will bring up the HDTV Settings menu and then proceed as above
Mar 25, 2011 | Televison & Video
My Vizio TV tells me, when I press the menu button, that it's unable to launch com.yahoo.widgets.tv.container. It worked fine last night.
Mar 24, 2011 | Vizio SV472XVT 47 in. LCD HDTV
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
No color on my T.V., before when the T.V. would warm up it eventually came back. Now there is no color except when you press the Menu button the Menu showes color. What is the problem and what can we do to...
Sounds like the signal board may have a problemn OR If the signal to the set is low it could lose color burst. If you are using a cable box .. try removing it and hook the cable direct to the TV and see if any change. If the set works ok without the cable box that box may be the problem.
Nov 22, 2007 | Panasonic PT-61G54 61" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
