Question about Irons
When I am pressing for steam on my intellidome, water is pouring out of the holes
I have changed the filter and descaled as per instructions
SOURCE: tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Posted on Aug 24, 2008
SOURCE: Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Posted on Mar 24, 2009
brnspncr
  • 67 Answers
SOURCE: Iron needed descaling so followed instructions on
It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
  • 10 Answers
SOURCE: singer press CSP1 has stopped steaming. I have cleaned the holes on the plate. filled the water tank. it heats up as normal really hot both light work but no STEAM what else can I do.
How many years have you had it for
Posted on Apr 20, 2012
SOURCE: steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
Posted on May 08, 2012
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Does it have a filter
need to know what brand of iron?,is water leaking or dripping from the baseplate?,are the holes in the baseplate clogged ?is the steam button on or off.
Len..
Oct 14, 2014 | Irons
Swan steam iron 2200w
To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the lime scale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any residual vinegar etc. Turn off and unplug the iron and pour out the remaining water. Descale completed.
To clean the base (soleplate) first, make sure your iron is completely cool before cleaning.
There are a number of things to remove various stains. For general stains rub the bottom of the iron with table salt and a soft damp cloth. For marks left by limescale (a powderey white) use undiluted white vinegar on a soft cloth. Some stubborn stains can be removed with a paste made from baking soda and water. What ever you use make sure you rinse and wipe the soleplate dry before using again. Never under any circumstances use a metal scouring pad or wire wool type cleaner, this will scratch, mark, and probably damage the soleplate beyond repair.
Nov 30, 2013 | Irons
Brown steam
Brown steam is normally associated with internal rust in the iron. descaling may help clean it up. To descale make a solution of 3 parts distilled water to one part white vinegar, about a teacup full and pour into the irons water reservoir. Switch the iron on and set it on to the highest steam setting. Place a clean tea towel or similar on the ironing board and steam-clean it with the iron for a few minutes. The vinegar/distilled water solution will break down and expel the limescale. Turn off the iron (unplug). Pour out the water and vinegar solution. Pour clean distilled water into the iron reservoir and steam-clean a new clean cloth for a few minutes. this will remove any risidual vinegar etc. Turn off and unplug the iron and pour out the remaining water.
Oct 26, 2013 | Morphy Richards Jet Stream 42271 Iron
Steam not working on iron then lots of water pouring out of holes
May 08, 2012 | Tefal Pro Express GV 8120 Iron
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Aug 26, 2010 | Irons
Hi, ive lost my instructions and need to descale my iron. could you please advise me how to do it many thanks jo
CDR, Scale Away, you can buy at the hardware. It will remove the deposits. After you get it descaled you need to use Distilled water that you buy at the grocery store in it. This will avoid it scaling again.
Vinegar and water, Citric Acid crystals, Usual dose 1 teaspoon per 200ml water works
Pour it in just like water and let it steam out, then repeat with water, steaming out over a rag, sheet or something.
Feb 13, 2010 | Irons
I need to descale my iron Do I just fill and dial self clean?
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 16, 2009 | Irons
Rowenta steam iron no longer steams
Your local grocery or hardware store will sell "descaler" for coffee pots and irons.
Mix as instructed (water/descaler) and pour the disolved mix into the iron. Set the iron on the highest steam settings (heat and steam volume). After it is hot, let it steam into the sink, pressing the steam button over and over to let the descaler work through all the tubes/passages, until it has all been pumped out.
Refill with more descaler (if it is not completely unplugged) and repeat until you are satisifed with how the iron is working.
After descaling, run clean water through it with the same process (but no descaler) several times.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 24, 2009 | Rowenta Professional DE841 Iron
Irons Logo
29 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
