Question about RCA DRC69705 7"" Dual Screen Portable DVD Player
Problem with RCA 7 dual screen dvd system showing No Disc when a disc is end player
Showing no disc on screen when a disc is in the player
SOURCE: rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Posted on Jul 17, 2008
sree-here
  • 61 Answers
SOURCE: rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
SOURCE: RCA DVD videoplayer says loading, then no-disc
I would  appreciate a response to the 10 bucks I sent in a couple of weeks ago.
Posted on Apr 05, 2009
  • 814 Answers
SOURCE: RCA DRC 8052NB will not read discs
This sound like a problem with the laser read circuits and it may be solved with a simple cleaning and using compressed air to clear the unit of debris .To do this you must take off the top cover of your unit by taking out the screws and lifting the top off. To clean the laser head you should use cotton swabs and isopropyl alcohol. put a small amount on the cotton swab and rub the swab gently back and forth over the head, until it seems bright and shiny.Check the transport carriage for dust and debris and also the gears. all these must be clean for proper operation. You may want to put a little lithium grease on the gears and guide rails for smooth operation. All this should be done in minute amounts so you do not over do it and cause more problems. If all this fails to allow you to use you disc player, Then you probably have a worn out laser sensor and will have to have it replaced. If under warranty send it in and if not try to find the part number and order it and either take in to a service center for repairs or do it yourself. Hope this helps you with your problem.
Posted on May 15, 2009
dap_music385
  • 15 Answers
SOURCE: rca portable dvd player model drc6318e doesnt not
first you must check if your portable loads cd or mp3. If it loads cd or mp3 the defect is lens and this should be replace by an expert. If both cd,mp3 and dvd didn't load you check first the ribbon wire for signs of disconnection and foldings and then replace it. If still your portable didn't work the most probable defect is MPEG board.To distinguish if MPEG or lens defect in lens shows malfunction such as not reading dvd but reading mp3 or cd, unwanted stop of play even with a good dvd.
Posted on Jul 11, 2009
Why does my philips portable dvd player not work
It is attempting to read the disc. Try another KNOWN GOOD disc. If you get the same error, try cleaning the lens using a lens cleaner disc or a dry q-tip. If no go, sorry, she's a gonner :(
Jul 20, 2014 | Philips PD7012 7" Widescreen Portable DVD...
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Hello
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
DvD Player will not play disc
The discs got warped due to heat.
Sep 05, 2017 | RCA DRC629N Portable DVD Player
How can I record a tv show onto a blank disc? I
Make sure you have the right DVD disc and the disc is clean if you do... (2) make sure you connected it right and are fully seated. LINE IN on your DVD-R is for the recorder part LINE OUT on the tv is to send it to the DVD-R If you done that try another RCA cable or two That should fix it
Jul 15, 2009 | Philips Magnavox DVD/VCR Dual Player
RCA DVD RTD 315 with wrong region
You can try this options..hope this helps;
RCA DRA4008 / DRC220N
  1. Turn player on with no disc in the tray
  2. Press MENU, 1, 6, 7, Mute
  3. Press EJECT and exit the menu
RCA DRC105N / DRC198N
  1. Open tray
  2. Press 1, 6, 7, 1, 9 on your remote
  3. Select region code (0 for all regions)
RCA DRC230N / DRC230L / DRC232N / DRC233N
  1. Power on player
  2. Open the tray
  3. Enter 1, 6, 7, 1, 9
  4. OSD shows current region
  5. Enter 0-6 for region setting before screen disappears
    (Enter 0 for region free)
    Display shows new region assignment (displays "ALL" if 0 is selected)
  6. Power off
RCA DRC612N
  1. Turn on the player without any disc inside
  2. Enter the code "321 789 456" before the player menu appears
  3. Select 'all' in the appearing list for regionfree
  4. Turn the player off
RCA DRS7000N
  1. Turn on the player while disc tray is open
  2. Go to the "Options menu"
  3. Press 8, 2, 1, 3, X (replace X with 1-6 or 9 for multi region)
RCA RC5215P / RC5220P / RC5231Z
  1. Enter 738565250001000X, replace X with the desired region or 0 for multi region
  2. Press INFO
RCA RS2030
    Turn the player on with no disc inside
  1. Wait for the menu to load
  2. Press INFO
  3. Press 0, 2, 8, 3, INFO
Apr 20, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Wont play
There is no simple "at home" solution to any of these problems listed. However, Since it tries to play or at-least plays Cd's, then that will indicate that affordable repair is possible. I have already repaired several of the Dual units already. With the 7" Dual screen sets, I had to replace the laser assembly or the spinner motor (not spinning fast enough). With the 8" Dual Screen sets, I found mostly that the laser ribbon was binding up in the movement of the laser and preventing it to move to proper position. These repairs should be done by a qualified technician.
May 17, 2008 | Polaroid 7" Two-Screen Portable DVD Player
RCA DRC69705 7"" Dual Screen Portable DVD Player Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
