Question about Dell Latitude 100L Notebook
No power from ac power add. to laptop
That all
    New Friend:
Try changing the battery pack in bottom of laptop. That's what happened to mine.
Posted on Jan 21, 2013
What Power Adaptor need for Boundless Technology ADDS 4000/260LF?
Judging by the information on it - it will work straight from the mains - the adapter is inside. check my link.
http://www.inlandassoc.com/wp-content/gallery/ADDS-4000_260-Spec.pdf
Feb 17, 2015 | Computers & Internet
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
I need a power supply wire for my LG p1
http://www.ebay.com/itm/Universal-Laptop-Notebook-AC-Charger-Power-Adaptor-96W-/280623506057?pt=Laptop_Adapters_Chargers&hash=item415676e289
http://www.ebay.com/itm/90W-AC-Adapter-Replace-HP-BT796AA-BT796AA-ABA-Notebook-PC-Power-Battery-Charger-/370594765290?pt=Laptop_Adapters_Chargers&hash=item56492b59ea
not sure if any of these are the right ones or wich country you are in there are some in america and will only post to america
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Sep 17, 2012 | iTEKIRO Replacement Laptop AC Power...
I just put a new 9 cell battery, two new 2GB ram cards & a new, blank hard drive in our Dell Inspiron 1525. But the screen does not seem to work when I turn it on, or after I put in an installation...
Remove the battery, and connect the AC power. Then, try to start it.
Disconnect the AC power, and remove the "new" disk-drive.
Then, connect the AC power, and try to start it.
Disconnect the AC power. Remove the "new" RAM, and put the "old" RAM back in.
If it does start, add the "new" disk-drive, and try again.
If it does start, add the "new" RAM, and try again.
Jan 15, 2011 | Dell Inspiron 1525 Notebook
I have a dell vostro 1500 laptop when i press power sw. the power led lits for a second then turns off again nothing else done
This normally is an indication that the AC adapter is not powering the system and the remaining residual power in the battery only powers the system momentarily. Things to try:
  1. If available, try a different AC adapter. If no known good adapter is available, then use a multimeter to see if 19 VDC is available in the DC connector. If system powers up on a different adapter, or the Adapter has no power at the DC connection, replace the adapter.
  2. Remove all drives, Memory, battery, and wireless cards, and see if the system powers on. If it does, add 1 RAM module, and see if the system boots. If it does, add other components back one at a time until you ID the failure. If system doesn't change, then replace the motherboard.
Dec 22, 2009 | Dell Vostro 1500 Notebook
My dell inspiron 9100 wont start the operating system and the little light with the A in the middle blinks and then turns off can u help me?
Remove the battery the ac adapter,the memory.the hard drive and the cd rom.Press and hold the power button down for twenty seconds.Replace the memory first then the battery and the ac ,power up if this works add the other pieces one by one.REMEMBER BEFORE YOU ADD EACH PIECE THERE MUST BE NO POWER ,NO BATTERY OR AC ADAPTER.
Good luck
Nov 14, 2009 | Dell Inspiron 9100 Notebook
No lights no power nothing
Remove the AC Power amd remove the battery..... Press and hold the POwer button in the "ON" position for 20 seconds and let go.
add the ac Power Only and press the power button this should turn on the laptop.
If this does not work you can try reseating the Memory dimms as well
Let me know if this solve syour issues
Oct 14, 2009 | HP Compaq nx6310 Notebook
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Can't go any further
If the system is still powering on then off, it is most likely a power issue.
First, remove the battery, see if the system will power on with the AC adapter alone. If no power indication at all (Which is what I expect) then there is a problem supplying power to the system. If the system turns on and runs normally without the battery, then replace the battery.
If available, try a different AC adapter (Ant Dell D-Series AC adapter will work) and see if the system powers on normally. If it does, replace the AC adapter. If you connect a known good ac adapter and the system doesn't power on, then remove the drives, the modem, wireless card and memory and see if any change. If still no change, then replace the motherboard.
If symptoms change after removing all removable items, add 1 memory module back and see if the system will POST. If it does, add items back one at a time till the bad item is identified, then replace that item.
Jun 10, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude 100L Notebook Logo
19 people viewed this question
Alun Cox
