Question about Refrigerators
Refrigerator leaking water - Refrigerators
    Genius:
  • Refrigerators Master
  • 1,669 Answers
You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
Posted on Jan 21, 2013
There is a thick sticky black substance leaking from my refrigerator for the past two weeks on the left front side. Frigidaire model p/n 241543966
Hello Melanie;
My name is Peter. I am a retired field service technician.
You do not have a refrigerant leak. Refrigerant is clear in color.
You have a water leak. The black sticky substance is either coming from your bottom condenser cooling coil or just general dirt under your refrigerator that accumulates over time. The coil under your refrigerator collects dirt as well.
You need to pull the refrigerator out so you can get behind it.
Unscrew the bottom back cover. Inspect for the water leak source. Your condensate drain pan may be leaking or dislodged.
The water line to your ice maker may be leaking.
Your water supply shut off valve to your refrigerator may be leaking.
Nov 01, 2014 | Refrigerators
My refrigerator is leaking water making noise and not making ice
It sounds like you have a leak (dry rot plastic tubing) on the ice maker water line. The leaking water is being picked up by you condenser fan near the water valves and probably causing the noise.
First, turn the water shut off valve to the refrigerator off.
You have a dangerous situation here. You need to stop the water leak. If the water leak gets to the electrical components of your unit, well it is dangerous!
You will be safe for now if you shut off the water.
You need a skilled technician to fix the problem. Just shut the water supply to the refrigerator off.
My name is Peter, retired Sears Service Refrigeration Technician. Pull the unit out so you can remove the lower back cover behind the refrigerator.
Oct 13, 2014 | Frigidaire Refrigerators
My refrigerator water dispenser leaks water in the water pan. The unit is about 10 year old. It just started leaking.How do I stop it from leaking?
If your water filter is located behind the grille at the bottom of the refrigerator the O ring seal is leaking. Happened to me. Get a new one.
Feb 21, 2014 | KitchenAid Superba Architect KSCS25INSS...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water is leaking from under the fridge
If your chest refrigerator is showing signs of age, it may begin leaking. There are a few methods for troubleshooting faulty refrigerator but knowing some of the obvious signs of why it might leak can be very useful if you need to fix it yourself. Leaking is not limited to older models so be aware that certain maintenance procedures can help prevent leaks in newer models.
Understanding Changeable Parts Prior to Troubleshooting
There are not that many serviceable or changeable parts inside a refrigerator. A refrigerator works on a very simple basis. It contains evaporator coils, condenser coils, a compressor, a compressor overload, a relay and a thermostat. These are the basic moving parts of a refrigerator but some of them are not serviceable.
The condenser coils condense the water and the evaporator coils disperse excess water caused by the freezing process. The compressor is a heating component which compresses excess water and recycles it through the system.
Defrosting
Remove the contents of your refrigerator and place them in an alternative area to keep them frozen. Unplug and defrost your chest refrigerator before you do any troubleshooting or maintenance. Wipe and clean the inside of the refrigerator so that when you plug it back in it, will free of any grime or loose bits of debris. A clean refrigerator will also help to promote visibility when it comes to fixing leaks.
Where is the Leak?
Once you have defrosted your refrigerator, you need to establish which part of the refrigerator the leak is coming from. It could be coming from the inside of the refrigerator and this would indicate a thermostat issue. Alternatively, it could be coming from the freezing unit at the back of the refrigerator. Water always finds a way to escape so your leak could be restricted to one place but the actual cause could be elsewhere. Locate the drain tube which is normally found at the back of the refrigerator. You will probably have to unscrew or un clip the backing panel.
Check the Drain Hole
If the drain hole on your refrigerator has become blocked for any reason, you will need to clear it thoroughly to continue getting the best performance from your chest refrigerator. The drain hole is a component within the lower works of the refrigerator through which excess water runs to be recycled.
Compressor Issues
Your refrigerator contains a compressor which evaporates the excess water from the refrigerator. The refrigerator will defrost excess ice and the water flows down the drain tube to a pan where the heat of the compressor evaporates the water. If your compressor has failed, the leak will be caused by the water failing to evaporate. Have a repair contractor replace your compressor or, if this is not cost-effective, you may need to buy a new refrigerator.
Thermostat
If your refrigerator is not freezing at all and is dispersing water in several places, you may well have a thermostat failure. Check that your refrigerator is cycling correctly prior to making changes or altering the thermostat. Only if the refrigerator is not cycling are you likely to need to change the thermostat. If you have checked all the parts of your refrigerator and you still cannot locate the leak, calling in a service technician might be the best answer.
Hope this will help in solving....
May 07, 2011 | Maytag Refrigerators
Water leaking from under refrigerator model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
Sep 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
