Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire plef398dca While baking, Range made a sizzling sound followed by a loud pop. It also blew the breaker and smelled like the magic smoke that makes all electronics work. I reset the breaker. The burner indicators showed "PF" but the main display was dead. When I turned a burner knob, the display showed "F5". Did the Main board fry? Did an element in the oven go? Both? Niether?
  • Official Brand Answer
  • 4,342 Answers
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Posted on Jan 23, 2013
Testimonial: "Thanks. Tech checked it out. EOC replaced. The oven relay torched both boards badly. The breaker did it's job in preventing a fire. Expensive fix, but still cheaper than a new range."
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I turned on my oven on my Frigidaire Range and
To be certain the elements are o/k you need to test them with a meter. I suspect one of them has failed.
You normally cannot always tell if they are o/k simply by looking at them.
Hope this helps.
Posted on Jan 11, 2010
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Morison,
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I turned on my oven on my Frigidaire Range and heard a popping sound. This blew the breaker. I turned the breaker back on and the stove top works but the oven, broiler and bake do not work at all. The...
Hope this helps.
Jan 11, 2010 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
328 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
