Question about Yamaha HTR-5930 Receiver
When I run my receiver in 7 channel enhancer mode it works well, but in surround sound modes, people's voices are barely audible. I have a ps3 connected and a newer direct tv receiver hooked up w
    Genius:
  • Yamaha Master
  • 1,054 Answers
Some surround modes don't use the center channel. This is where most vocal tracks go to.
Posted on Jan 21, 2013
SOURCE: my yamaha htr 6050
Make sure your audio output on your PS3 is configured properly. You have the ability to chose which port the audio is coming out of.
The 6050 does NOT process audio signals coming in on the HDMI port. The amp is weak, I had one. With the 6050 you will have to use the AV multi coming out of the PS3 and use the special cable that came with the PS3 to convert that signal to the RCA and connect that to the 6050.
Posted on Jul 27, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
SOURCE: Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Posted on Mar 21, 2009
satavlad
  • 405 Answers
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
When i listen to music on my receiver i can only hear the music i can barely hear the voices what would be the cause of this problem
Do you have a surround mode turned on? Most vocals will come through the center channel. If you have a surround mode selected, and no center channel speaker hooked up you will lose vocals.
Jan 16, 2013 | Pioneer VSX-515 Receiver
I have a Onyko TX-SR303 5.1 Receiver and sound is only coming out of left front speaker.
Could be the IC that controls the various sound/surround channel modes. Had that happen on my Pioneer receiver.
Charged me close to 200 bucks to fix!
Aug 24, 2017 | Onkyo TX-SR303 Receiver
Center channel is too quiet for dialogue from PS3 movies
turn the other speaker decibal levels down then increse main volume until you are satisfied.
Feb 06, 2010 | Denon AVR-1907 Receiver
My playstation has no voices when playing blue ray
You need to check the settings from the menu.
It may be in 5.1 surround sound mode - check the audio setting from the DVD menu and switch between AC3 and the different surround ones.
Hope you get the right audio channel after playing with that menu.
Mar 18, 2009 | Sony Playstation 3 (PS3) Console
In THX mode, no sound from center channel
hello if you already switch your center speaker with other and no sound still even in all modes you right you got a problem inside...do this to be shure you have a problem turn it on discnonnect the center speaker and measure with a voltmeter the center output and if is delivering under a 3 volt ac take it to repair shop it has a shortcircuit,.................saludos
Nov 27, 2008 | Onkyo TX-NR801 Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
Very bad recording
Be sure you are in the SP record mode and use the dictate conferance setting depending on your environment.
Oct 06, 2007 | Olympus DS-2300 Digital Voice Recorder
Poor voice track but great sound.
Unhook your center channel speaker and see if it still goes into protect.You might have bad center speaker
Sep 09, 2007 | Sony STR-V555ES Receiver
Yamaha HTR-5930 Receiver Logo
149 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
