Question about Brother Sewing Machines
The bobbin thread keeps breaking
Have checked needle is inserted the right way it is the bobbin thread that is breaking
  • Brother Master
  • 7,365 Answers
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Posted on Jan 21, 2013
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
  • 22 Answers
SOURCE: thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Posted on Jan 12, 2009
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
Why does the thread break on my sewing machine?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 01, 2014 | Sewing Machines
Why does the thread break once you start sewing?
Jul 11, 2014 | Husqvarna Sewing Machines
What to do when the thread keeps breaking
Jul 10, 2014 | Singer Sewing Machines
Thread keeps breaking
Sep 02, 2013 | Pfaff Creative 4.0 Sewing Machnie
Passport help
Aug 23, 2013 | Brother Sewing Machines
Thread breaking
The needle thread breaks
Aug 13, 2012 | Janome Sewing Machines
The thread keeps breaking. Could the AUTO tensioner be the problem ?
here are some suggestions, hope they help
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 18, 2011 | Baby Lock Ellure
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
Lower thread breaks
Sep 12, 2011 | Sewing Machines
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
wrong foot is attached
needle clamp screw is loose
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 21, 2010 | Husqvarna Designer I
Sewing Machines Logo
252 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
