Question about Microsoft Xbox 360 Console
The problem is that there is volume but no picture.
One day it was working and the next minute not working, the disc is running and you can hear the volume and so the disc is working but there is no picture. Can you help
  • rehana_ajay Jan 26, 2009
    Thank you for your response and sorry for my ignorance but how do I fix this. I mean is it like a switch or what
    Problem Solver:
  • 3 Answers
It happened to me before i dont know if the same problem is with your but all i did was inspect the cords and found out i had it on hdtv instead of tv :~)
Posted on Jan 26, 2009
What is wrong with my radio??? AM works but FM doesn't.?
I'm very sorry to say this but, The internal FM modulator has blown & the only way of getting FM back is by replacing the head unit.
Sep 21, 2012 | Cars & Trucks
I have noticed that the cooling fan does not work on my bdp-S350 and am wondering if it only works depending on temperature, would greatly appreciate your help, thanking you in advance. Austin Donnelly,...
The cooling fan on your BDP-S350 should work all the time, because the system gets very hot in just a few minutes. Try playing a Blu Ray disc with the volume down, with in 10 minutes the fan should start running if not you have a defective fan or control electronics. Try spinning the blade of the fan when its on with a non conductive material ( tooth pick ).
But if the fan starts running with in 10 minutes of the movie ( Bluray ) all is OK and your system has a thermal sensor built in. Its done to prevent you hearing the wind noise during a quite passage of a movie ( some find it annoying ).
Mar 28, 2011 | Sony BDP-S350 Blu-Ray Player
Volume but no picture
Take the bottom off and check the connector to the screen if your warranty is void anyways you can't make it worse I hear it works loose will try this on ours next time
Jun 28, 2010 | Sony DVP-FX810 Portable DVD Player
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Gateway- built-in laptop Speakers not working
Seems to me the speaker is just plain broken. You'll need a new one, contact your vendor for repairs, or you will have to live with using external speakers/earpieces...
I hope you will get your replacement,
Yannick.
May 25, 2009 | Gateway Computers & Internet
MLTD3222 has sound but no picture
I have one of these in my shop with same problem. Unit has sound but no backlights due to the powersupply/inverter board ( top board in metal box. The lights come on for a second and go out. Problem was originally intermittent. You can order this board from Fox Intl Part but will take a minimum of 12 weeks. Look at the lower right corner of this board and locate the dip switch of 4 positions. the bottom one is labeled " normal & burn " Try moving it to "burn" My set is in the burn position and has been running for 2 days now OK
Nov 04, 2008 | Televison & Video
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Ps2 - stops reading disc
there is a little wheel type thing that the cd sits on when it goes into the drive, the wheel makes the cd spin, these often wear out , after you play it for 27 mins the device heats up which causes it to slip , which would most likely be the noise that you can hear , it wont cost you much at all to get this fixed at a game console service store, if your sure the cd is still spinning after 27 mins , and making the noise , it is the laser cog slipping , in this case it is best to replace the whole laser section, which is one part , and if your handy at things like that i suggest you just go and buy the laser reader from a game console repair store , and swap it over your self , it is pritty simple to do ,
Nov 17, 2007 | Sony PlayStation 2 (PS2) Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
