Question about Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic lumix dmz-tz3 has a purple/magenta image
Just changed out the ccd on this model to fix a very dark (almost black) image and now I have a purple/magenta image.
  • Nancy Fish Jul 26, 2013
    Same problem here. One day fine then just a blurry mess. How do you get support, service or replacement of the CCDS unit is that is the problem. Purchased the camera in 2009
    Genius:
  • 1,019 Answers
Sounds like the CCD unit you just installed has a problem or the camera has a problem processing images which is the main system board. Sorry but it sounds like you are beating a dead horse.
Posted on Jan 25, 2013
It is apparanetly the ccd sensor letting to much light in those made around 2005 or so were faulty and ther is a chance of it being fixed or camera replaced as there was a recall of sorts done on thes eccd sensors in many brands of cameras
Posted on Jul 01, 2013
  • 14 Answers
SOURCE: my Panasonic Lumix DMC-TZ3 was soaked in water.
It depends on how wet it was, if the entire thing was submerged, or even a large portion, it probably will not.it may turn on but it is likely that the lens will be damaged permanently. However if it was just wet upon the outside, like it was used out side during a rain fall, and then wiped dry every thing should be fine.It all depends,try drying it out thoroughly, letting it sit out with all lens caps and lens attachments removed, battery doorway open. is the best thing you can do. I hope that everything works out for you. God bless...
Posted on Aug 17, 2009
dlundmark
  • 797 Answers
SOURCE: My Panasonic Lumix DMC-TZ3 has a black screen. I
Check the menus, if they work, then there is a possible ccd sensor defect.
Posted on Oct 31, 2011
SOURCE: lumix pictures blurry
you might have accidently slowed your shutter speed in the settings
Posted on Dec 18, 2007
alfa104
  • 78 Answers
SOURCE: memory card locked panasonic lumix dmx tz3
Format the sd card and try again.
Posted on Jun 13, 2009
leecom72
  • 4806 Answers
SOURCE: How do you unlock the memory card on the Panasonic
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Hope this helps.
Good luck
Posted on Jun 22, 2009
Ccd problems
first check ur ccd's screen contrast and brightness and etc. Then check battery of that is working properly, and also check it's cicuit plate get not hit when you use your ccd. If problem is Couldn't solve by this then contact your nearly service center.
Aug 26, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
DMC TZ3 lcd sceen ok on playback no image on shooting
Sounds like a possible bad CCD sensor.
This camera had ccd problems.
See this link:
http://www.merchantcircle.com/blogs/Darntoothysam.Digital.Camera.Repair.952-236-7243/2009/7/Digital-camera-defective-CCD-recall-Get-your-camera-fixed-FREE/301718
Call the factory for possible free repair.
Oct 29, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Panasonic Lumix DMC-FX9PP and the monitor suddenly went completely dark and has stayed that way. What caused this and how can I reverse/fix it?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using fixya
Aug 22, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a panasonic tmc tz3 camera that has a purple color when i try to take a picture
I am sorry to hear regarding the trouble. This is a common problem on these models. It is either a faulty CCD sensor or LCD panel. If this is a problem while taking new images,however old images are still perfect - this indicates a problem with CCD sensor unless this is an indication of faulty LCD panel. Unfortunately, in both situations, repair is never advisable as the cost of repair would be high as compared to cost of the camera. It would be wise to invest in new camera. Be advised that if it is faulty CCD sensor, there were few recalls in the past for old models.So, it would be worth giving a call to their customer service and ask whether there is any recall or not. If not, they might offer a replacement in lieu of this camera at a highly discounted price.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 15, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
The screen seems not to get light from outside everything is sort of purple
Some symptoms of a defective CCD (Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
Jun 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Hi my panasonic DMC-TZ3 screen is very distorted showing a pink and purple colour, it is like this in all modes and the picture is distotred when a shot is taken,
It is ccd imager chip failure problem in DMC-TZ3 and ccd imager chip will be replaced to solve this issue.
CCD Imager chip part number is VEK0L04 and available in PartStore.com for $141
Local camera repair shop will replace it because camera will take apart and expert tech is required to do so.
Thanks.
Feb 27, 2011 | Cameras
My Lumix DMC-TZ3 seems to be losing colour. Sunny scene shots appear washed out. I have tried changing the white balance settings but that does not fix the problem. Do you think it is fixable or is my...
i think this is the CCD problem. did you recorded any laser show or direct exposer of ccd to SUN will do these kinda problems. take it to service center . replacing ccd will work . aaarwind
Jan 19, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ1 spots on pictures
Upgrade to the TZ3 or TZ5. TZ3 is smaller and has a great wide angle lens. You can get a very good buy on Ebay for a used or new TZ3 because it has been replaced with the latest TZ5.
You can likely get about $40 dollars for yous, if it has all the stuff it shipped with, even with the problem you mention, since repairmen buy time to fix and resell on ebay.
Oct 23, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
905 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
