Question about OmniMount VB60C B 23""-42"" FU
How to adjust the tv on the omni mount vb60c
The television is leaning down and we need to know how to tighten it.
Want to reset the v-chip on my 2001orion tv model # 1933
Omni TVs have a child lock that allows parents to prevent children from watching specific channels or television shows with certain ratings. To activate or deactivate the controls, you need the four digit pass code. If you forget the pass code or if the lock gets set accidentally, you can still unlock the TV.
• Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
• Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
•Take your television to a TV repair shop if you are still unable to unlock the TV. The problem may be with the wiring, so the repairman may have to rewire the TV
Aug 12, 2012 | Televison & Video
Did not get instructions for ob60fm omni mount
Here's the link to the OB60FM omni mount place page. You can download the manual and the wall template there.
http://www.omnibasics.com/Product/Wall_Mounts/OB60FM/
I hope this helps you.
Bobya
Jun 16, 2011 | Televison & Video
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
I have an ULPT-X Omni Mount that I will be using with a Samsung 65" LED. How do I mount the ULPT-X to make sure that the exact center of the TV will be in the center of the wall space it will be hung on. ...
What do you mean by centered on the top and bottom? It doesn't need to be centered in the exact part of the wall for the tv. it all depends on what your viewing height is for where you want the tv vertically. Once you figure that out you mount it where you want it for your personal viewing preference.
Thank you,
Lee
Oct 26, 2010 | Televison & Video
I just purchased a 52 inch phillips tv and the stand that the tv sits on adds 2 inches which doesn't allow the tv to fit in my entertainment center. What can I do?? I need a shorter stand...
Just take off the stand altogether if you can lay the TV close enough to a solid vertical support.
My 47'' Philips spent about a year without a stand sitting on a desk and leaning on a wall.
It's heavy enough and as you approach to completely vertical position its main force will be pointing down, not forward.
If you can't lean it on anything solid or if it doesn't sit well while in an entertainment center...not sure what I'd suggest....short of adjustable wall mount stands...
Nov 07, 2009 | Philips 52PFL3603D/27 52 in. LCD HDTV
TV Locked - Omni v6833nf
Use the original Omni remote to turn on the TV. press the "Function" and "Mute" buttons at the same time. Omni technical support: (416) 260-0047.
Mar 25, 2009 | Televison & Video
Omni tv t8005nf locked tv
on the omni tv remote...press the button with a square and a + sign for a couple of seconds
May 27, 2008 | Apex Digital GT2011S 20" TV
Stand
You would need an actual wall mount bracket for your TV. Here is a link that you should be able to find what your looking for.
http://www.mountsandmore.com/TV-Mounts-C135.html?refid=OV81.tv+wall+mount
Mar 12, 2008 | Televison & Video
Wall Mounting
I purchased my tv mount from Ultimate Electronics/ Las Vegas, NV. The name of company is Omni Mount, model: U2 Fixed. The phone number is 1-800-MOUNT IT. Good Luck.
Mar 12, 2008 | Protron PLTV-32 Television
Bracket for tv
use shelve brackets, I did and they worked fine
Jan 18, 2008 | Akai LCT2715 27 in. LCD Television
OmniMount VB60C B 23""-42"" FU Logo
22 people viewed this question
Top OmniMount Televison & Video Experts
Are you an OmniMount Televison and Video Expert? Answer questions, earn points and help others
