Question about Kenmore Oasis HE 27082 Top Load Washer
Cycle Signal Won't quit beeping
The cycle signal will not quit beeping. It is going back and forth between on & off. It wouldn't start so I unplugged and the cycle started then the beeping began again. The washer is now running. When I push the button is does nothing.
  • 6 more comments
  • Lisa Macke Jul 18, 2007
    Called Sears & they told me a technician would have to come out & fix it.
  • mrjr Nov 15, 2007
    I have the same problem with the beeping noise throughout the washing cycle and my matching dryer also does the same thing.
    Can someone walk me through fixing it myself?
  • dailywasher Nov 15, 2007
    I had the same problem and just unplugged the machine when I finished washing. When I turned it on and selected my wash cycle, it always defaulted to the clean washer cycle. After several tries of turning the power off and on, it would finally work. The bad news is that I did this for several months. This week when I plugged it in and pushed power, it didn't come on at all. I've got a service appointment scheduled now.
  • Anonymous Dec 27, 2007
    same thing with our machine, 6 months out of warranty. sears waived the 72.00 service fee, but still cost 314.00 for the control board, then after it was fixed, it started doing it again!!!
    a third call to sears national customer care revealed the "user interface" needed to be replaced too. after alot of angry words from me, the service operator offered me a 20.00 gift card. what an insult. the service technician who called me said he would put in under warrantee. finally someone who cared!!!!
    what happened to standing behind your product?
    what happened to customer service?
    an 800.00 washer needing 314.00 put into it to fix what is obvioously a design flaw!!!
  • HounDogg Jun 25, 2008
    I too purchased a Kenmore Elite Oasis model 2704 and it starts to beep about 30 secs to a min after i start it. While the beeping noise is going off my cycle signal goes back and forth.
  • dsms Jul 03, 2008
    I have the same problem with the Auto Temp Control beeping and continually changing while washing. I contacted Sears to see if there was a recall on the Kenmore Oasis (Top Loading) and there is one by Whirlpool for the control board. Why didn't they contact people who purchased these machines. Call this toll free number 1-800-659-7026 for the Sears Recall Dept. They are replacing my part and labor at no charge.
  • aelac Nov 17, 2008
    Same problem on a Kenmore Oasis HE 27072602 with the continuous beeping on the Cycle Signal. Was able to romove the console interface but the printed circuit board was like trying to read hieroglyphics. What is the repair operation? Can that particular circuit be disconnectd?
  • Anonymous Mar 27, 2014
    The washer was acting as if it was going to come on like normal, but when I hit the start button, the dryer light came on and it beeped about 6 times. Now it does nothing but beep about 6 times
  • 5,911 Answers
This is a common problem with the Oasis. The problem is with the interface control board in the console, and/or wiring harness to the board. I have repaired three of these problems in the last 6 months and it was the interface control board each time. The machine will still function normally except for the annoying noise. I don't know of an easy way to defeat the noise functions to the interface control board, or if it should even be attempted. You could cause more harm than good. It can be a bit pricey to replace, and can be tedious to remove. If you wish to attempt to repair, let me know and I can give you some step by step tips on how to remove.
Posted on Jul 18, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 19, 2007
    Might be a good idea if you still have a warranty or service plan. That way, if something gets broken in the process of trying to repair, the cost will lie with the repairman and not you.
  • Nicole Ryan
    Nicole Ryan Apr 01, 2016
    I'm having this same issue, but with more complications. Can u help me?
    So Ive had to remove the top portion, the (WM control panel) and rattle wires of all sorts in order to get the beeping to stop. When it beeps it will not respond to the buttons at all to start wash etc. So I wiggle wires and tubes etc. and when the beeping stops I QUICKLY push START!!! It will then start, and immediately start beeping and will not stop until I lift the lid, but is washing as normal..
    I am trying to pinpoint the exact wire it could be. I notice if I push the clear tube dwn, wiggle the brown wire with plug, and then squeeze the blue wires
    (washer wire harness) it stops it from beeping for a few. almost seems like a loose wire not all the way pushed into the plug (connector)and is not getting a constant connection...
    Am I close?
    I do not want to spend unnecessary money on parts if it wont fix the issue.
    I have had to constantly keep buying warranty's for it since I purchased it 10 yrs ago at 250+ a pop per every 1-2 yrs.
    After figuring out I had spent $3625 in warrenty's and parts and purchase inthe last 7 years, I cant see spending much more, although I LOVE this washer when It does work...
    Then techs weren't fixing the right issues (rod) and takes weeks to get one out. now its a recall of course!!ehhhh
    I stopped buying the warrenty's 3.5 yrs ago and resorted to self fixing the pump, lid lock and basket issues. Now this issue!!!!
    I am very positive Im in the ball park of the real issue but want to narrow it down.
    I'm thinking its either of these: Washer wire harness?, Washer Electronic control board?, washing machine control panel?, or Interface?
I too have the same problem. Washer was 1 yr old in April. Did not purchase extended warranty because i thought i'd get at least a year or two without any problem! I called Sears and told them others have had this problem but they would not offer me any compensation.They said unless a recall was out on this washer they couldnt help me. They did tell me I could purchase a 1 yr warranty for $200 which i did. They are sending out a repairman and will waive the service fee of $59 and any parts or labor. Not a good deal, but I figure this part will cost at least $200!
Posted on Aug 18, 2007
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
Beeping sound when cycle is finished just started after 8 years. how do I turn it off?
Welcome to FixYa.
I think can answer your question..."beeping sound when cycle is finished just started after 8 years. how do I turn it off?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
? If the display blinks with a "0", you will hear
no signal (indicates OFF).
? If the display blinks with a "1", you will hear a
LOW volume signal.
? If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
? If the machine beeps, then the Cycle
Completion Signal has been enabled.
? When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Nov 06, 2010 | Bosch SHU9915UC Dishwasher
How do I turn off the annoying beeping alert after the cycle is complete?
Hello Joanna,
Welcome to FixYa.
I think I can answer your question..."How do I turn off the annoying beeping alert after the cycle is complete? "
Follow these steps for the SHV6800 will be the same...
**SHV 6800 Delay Start Hours**...should be applicable to yours, let me know if not.
LOW volume signal.
function:
program mode.
Regards,
Macmarkus :)
Oct 18, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
• If the display blinks with a "0", you will hear
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
function:
• If the machine beeps, then the Cycle
• When you push the button again and it does
program mode.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Beep's incessantly after cycle is complete. How can we re-program it to turn off after one or two beeps?
Hello, welcome to fixya.
1. Open the door, hold down the “Quick Wash”
The “Quick Wash” light will blink (program mode).
2. While the light is still blinking, push the “Quick
Wash” button.
doesn’t beep, it means that the Cycle
program mode.
Good luck.
macmarkus :)
Jun 28, 2010 | Bosch SHU9915UC Dishwasher
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Nov 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
667 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
