Question about MSI PM8M-V Motherboard
The back panel of the motherboard is not working but when I test the memory its ok and when I put the video cord in the back panel there's no display. and I try to put a video card in the agp or p
  • MSI Master
  • 3,606 Answers
Hello download the manual here:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Manual
Look here also:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Check the power supply, and all your power connections again.
Try to reset the cmos by removing the battery, and inset it again.
Look also for bad caps on the mainboard:
The back panel of the motherboard is not working b - 1_23_2013_12_52_21_am.jpg
If they look like this,scrap the mainboard.
It does not pay, to let them be changed.
Good luck
Posted on Jan 23, 2013
  • 33 Answers
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Posted on Feb 19, 2008
  • 55 Answers
SOURCE: MSI motherboard model 6734 AGP interface
Looks like your motherboard is a MSI KM4AM-L detailed here:
http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=572&maincat_no=1
If so, then it has an AGP slot which will run at 4x and 8x.
Remember to check the BIOS settings after you install it to make sure it is set to 8x, if that is what your card will take.
Posted on Sep 22, 2008
ghoff1
  • 167 Answers
SOURCE: will only work with agp slot
i would get another agp card and be done with it. these cards can be very cheap now. keep the pci graphics card in the hp. i'm sure that is better than the onboard graphics. good luck.
Posted on Apr 23, 2009
naebarbat
  • 508 Answers
SOURCE: MSI 848P NEO-V: PCI bus - no drivers for real time clock
try to reinstall your driver from here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=582
Posted on Jun 05, 2009
compdoctor20
  • 172 Answers
SOURCE: ATI RADEON X1650 512MB DDR2 AGP not detect on my MSI PM8M-V
I have checked you motherboard and the graphics card you mention is supported by your board. See the direct link to the msi website and save it to favourites. http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=205 More help? chris http://www.motherboardsrus.net
Posted on Jun 06, 2009
GA-990FXA-UD3
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 05, 2012 | Gigabyte AMD Phenom II X4 960T...
Intel d865perl beeps on startup and then shuts down
More than likely it's the memory or video card that is causing the beeps.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 29, 2012 | Intel D865PERL Motherboard
Asrock no da video
If the computer boots or it seems like it booted up all the way except the screen is black try the steps below:
If it is a laptop:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If it is a Desktop:
Try using another monitor on the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays and works ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and not display then your Video Card in the computer is bad.
If the computer is not powering on or did not boot up all the way try the steps below:
Remove the Power Cord, (If desktop Open the Case) (if Laptop, Remove the battery, Remove the cover that houses the memory) and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 16, 2012 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Motherboard cpu fan runs, no post beeps then power down
You either have a Video Card issue, Memory issue or you need to apply a fresh coat of Thermal Paste around the CPU and Heatsink on the motherboard. Also reseat the CPU by taking it out and putting it back in.
Make sure the video card is in the slot as far as it will go. Push it down all the way in the slot.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery (on a laptop) the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
May 13, 2012 | ASUS Computers & Internet
Blinking power light
Sounds like your motherboard has an issue. It could be a problem with the memory, the video card or the the motherboard itself.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Computers & Internet
ET1161-07 onboard Video gone bad. I tried a Gforce 8800GS 384mb card, that works, and I have no video, 1 long beep that never stops. Ican't get into the bios with the onboard video or the new video and...
Hi.
One continuous beep means that you probably have not put the graphics card in the PCI express slot or there is a short somewhere in the system.
Follow these steps to try and resolve the problem:
Remove the power cord and the video lead from the back of the machine and then remove the side panel to reveal the motherboard.
Remove the graphics card and take a look at the PCI Express slot for dust. If you see any dust get a clean, dry paintbrush and clean the dust from the slot and then blow on the slot to remove the rest of it.
Next look at the brass contacts on the graphics card and clean then. Re-seat the card making sure that it is fully pushed down in the slot.
Check that any other cards you have installed in the machine are seated properly.
Without putting the side panel back on, connect both the video lead and the power cord and turn it on. DON'T TOUCH ANYTHING INSIDE THE COMPUTER!!!
If the computer boots up turn it back off and put the side panel back on. If not then please post back telling me what the computer is doing.
Good luck.
Jun 07, 2011 | eMachines ET1161-07 Desktop PC
Gateway Laptop MC8741 will not turn on. Replaced battery....replaced power cord. Noticed that fan was not working a day prior.
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 23, 2010 | Gateway MX8741 Notebook
When start on asus motherboard 1beep+1beep sound total 2 beep sou
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Jun 19, 2009 | Intel Motherboard
Motherboard asus p4vp-mx
Do you have a video card installed or are you using the built-in video? If yes, check the video card if it is installed in the motherboard firmly, first unplug the power cord in the power supply then try removing the card then install it again in the agp slot carefully pushing it firmly, then put the power cord back to the power supply and try to power it on. Does it have a display now?
If the video is still blank try reinstalling the memory module in the motherboard, first turn the pc off then unplug the power cord, next remove the memory modules from the motherboard by simultaneously pushing locks on each side of the memory, then use a clean paint brush to remove any dust on the memory modules copper contacts and also clean the memory slots in the motherboard, then install the memory back to the slot making sure to match the notch near the middle of the memory to the memory slot in the motherboard, and also make sure that the locks on each side is firm. Then connect the power cord to the power supply then turn it on. Does it have a display now?
In the condition where your using the built in video and a known working memory and still there is no display, the motherboard could be defective already.
Jun 18, 2008 | Computers & Internet
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
MSI PM8M-V Motherboard Logo
57 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
