Question about Home
I have a spring loaded sink stopper that is stuck in the closed drain position. How to I get the stopper to release as pushing it with thumb isn't working
5 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: pop up vessel sink drain
Look underneath the sink and you will find the lever that moves the drain up and down. It is probably stuck.
Posted on Jan 30, 2009
  • 30 Answers
SOURCE: Our bathroom pedestal sink is very slow drain and
You shouldn't have to disassemble everything in order to get to the trap (elbow joint). Most pedestal sinks are designed so that you can get to the trap from the back (generally after getting down on your hands and knees and crawling around with a flashlight). Most sink stoppers that are worked from the faucet itself have a little bar that extends down the back of the sink behind the drain. It will clip with a little metal piece to a lever that sticks out the back of the drain before the trap. The lever goes through a hole in the drain and pokes into a hole in the bottom of your sink stopper. As you move the lever, you will notice that your stopper goes up and down.
Unclip the rod from the lever and you should be able to unscrew the lever from the back of the drain (don't loose the little gasket that sits inside the screw-cap as it keeps water from leaking out here). At this point, you can pull out the stopper and see what is going on. If cleaning off the stuff attached to your stopper doesn't solve the problem, you can then remove the trap to see if anything is clogging that. Hopefully, by this point, your sink clog has been identified and you just need to reassemble, making sure when you put your stopper lever back in that you actually get it into the appropriate hole in the stopper itself.
If this doesn't solve your problem, it's more serious and you probably want to call a plumber as the issue is either a clog farther along or a problem with the venting of the sink drain.
Posted on Sep 18, 2009
  • 19 Answers
SOURCE: CHIPPED PAINT ON BATHROOM SINK DRAIN STOPPER
you need to remove the brass ring from the tub and buy acan of spray paint for metal you will be able to find it in a brass finish
Posted on Feb 02, 2009
  • 63 Answers
SOURCE: Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Posted on Mar 16, 2009
My son put tp down the drain. How do I remove the sink stopper? Doesn't seem to unscrew?
it unscrews but from the underneath up
you will have to remove the "S" trap only as what ever it is will be stuck in that bend
Jan 04, 2016 | Plumbing
Tip
Simple Removal of Stuck Sink Stopper
I found an easy solution to removing a stuck stopper recently when I was fixing my kitchen sink and the stopper became vacuum-stuck. Instead of trying to pull on it (which will not work since the pressure is too great), or trying to release the vacuum by prying up an edge with a knife or other instrument (which would damage the stopper or sink), I used a (clean) toilet plunger to plunge the stopper out. Simply place the plunger squarely over the opening where the stopper is stuck and give it two good plunges. I got the stopper stuck several times while fixing the sink and this trick worked every time for getting the stopper unstuck. Make sure you are using a plunger that's cup-shaped (stands upright on its own), and not the kind that has a bulb at the end.
on Jun 28, 2014 | Home
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Belle Foret pop-up drain stopper won't release
The drain should be able to pop up after vigorous pushing down on it. When you get it released, you will find it is clogged with goo. You will have to disassemble the pop-up (remember the order of disassembly) and clean all the moving parts then reassemble it.
Apr 06, 2014 | Belle Foret Bathroom Sink Faucet -...
Drain stopper is stuck
try turning the top of stopper with fingers. They are generally " locked in with a twist" and can be unlocked the same way. good luck!
Dec 24, 2013 | Franke Home
Stopper no longer stays in up position on my bathroom sink
Solution to the most common design...
If you can pull the stopper completely out of the drain with no resistance, do this.
On the back side of the tailpiece that attaches to the bottom of the bowl, there is a rod coming out of the back side that has a nut holding it in. Unscrew that nut and pull the rod out part of the way. There usually is a loop molded into the plastic on the lower end of the stopper where that rod inserts into. Turn the stopper until that loop is aligned toward the faucet and insert back into the drain but not all the way (keep it held up about 1/4-1/2 inch from completely closed). Reach under the sink and feel for the rod while you are holding the stopper in place and push it back in while you "feel" for the loop. You will know it is inside the loop when you can't pull the stopper out with not resistance. Screw then nut back onto the threads and finger tighten it until it has enough friction to hold itself at any position.
Hope it helps...
Oct 02, 2013 | Price Pfister Plumbing
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 | Plumbing
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
Mar 15, 2009 | Home
Pop up vessel sink drain
Jan 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
Home Logo
3,697 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
