Question about Gateway Computers & Internet
Resetting bios password on gateway netbook mt6728
  • 112 Answers
SOURCE: bio's password reset
Several options:
http://xtreview.com/review113.htm
http://www.pwcrack.com/bios.shtml
worse-case scenario: replace motherboard
Posted on May 23, 2009
parrotheadpc
  • 2600 Answers
SOURCE: How do I remove the mainboard battery on a Toshiba
I know this not exactly what you are looking for but its all Ive found so far....it is a tear down guide for the NB but it is in Italian...lol It has good pictures as a guide though. I'll keep looking.
http://netbookitalia.it/toshiba-nb100-guida-al-disassemblaggio.html
Posted on Sep 10, 2009
SOURCE: gateway mt6728 recovery boot disk
you can get the recovery disk from Gateway's website, here is the link:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=gateway
Posted on Nov 30, 2009
  • 67 Answers
SOURCE: gateway mt6728 doesn't switch on and the red led
Sounds like it needs a new power source or motherboard. Since it is immediately turning off after the red lights then it's probably a hardware problem since there is no time for the software to do anything.
Posted on Dec 26, 2009
Testimonial: "I think it was the power supply. After letting everything cool down for a while, it worked again"
prasant1990
  • 59 Answers
SOURCE: Reset Bios Password
At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory.
However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
O 70 17
O 71 17
Q
PHOENIX BIOS
O 70 FF
O 71 17
Q
GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
O 70 2E
O 71 FF
Q
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Using the jumpers
The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or vice versa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "brute force" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry.
Posted on Jul 07, 2010
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
Apr 18, 2014 | Gateway LT2104u Netbook
Forgot login pasword on gateway lt4010u
If this is a Windows password, then you can ask local laptop tech to erase the password. Usually it cost $25 - $50. If this is a BIOS password, then you need to contact laptop manufacturer.
Feb 18, 2014 | Gateway LT Series LT4010U Intel Atom N2600...
Factory reset LT4010u gateway netbook
You press the F11 key at start up and you should be presented with the Gateway System Recovery option. That will allow you to restore your computer to it's originally installed state.
If this is because of a bios password...
Please contact Gateway, I do not assist in helping to bypass security features.
Dec 25, 2013 | Gateway LT2030u Netbook
Remove bios password
BIOS, which stands for Basic Input Output System, is the most low-level operating system on your computer.
BIOS is responsible for automatically performing a number of tasks, such as setting the clock speed of your computer's processor and determining the timings of your computer's memory.
Resetting a BIOS password on your Gateway computer can be accomplished in multiple ways, so choose the one that best fits your situation.
· 1
Navigate to xs4all.nl and attempt to use the master passwords contained therein (see below). http://www.xs4all.nl/~matrix/mpwlist.html
These are BIOS passwords built into the system that can be used by technicians and other service personnel when working on an otherwise locked computer.
·2
Contact Gateway and speak to a customer service representative about obtaining a master password for your particular model if none of the passwords in Step 1 work (see below).
http://support.gateway.com/support/contact/chat.shtml
·3
Open your computer case using a Phillips screwdriver (or no screwdriver at all if you have a case that supports screwless entry).
Look in your operating manual for the location of the BIOS chip on the motherboard.
Remove this chip by gently wedging the screwdriver beneath it and prying it off the motherboard.
·4
Wait five minutes and place the chip back into position on the motherboard.
This will reset the memory, removing the password and allowing you access to your computer.
Nov 26, 2013 | Gateway LT Series LT4010U Intel Atom N2600...
How to Gateway, LT4008u, reset password?
In the interest of theft provention, this info is not easily attained if it is the bios password
Feb 01, 2013 | Gateway LT4008u Atom N2600 Netbook
MT6728 gateway laptop not recognizing HDD password
Remove cmos battery for a while then setup bios with a new password.
May 12, 2012 | Gateway Computers & Internet
I have the 7 in ch sylvania notebook and i forgot my password. How can I reset it?
Remove the CMOS Battery
Detach the CMOS battery from the metal holder. Some Gateway CMOS battery holders have tabs on both sides, while with others you can lift the battery out. Press down on the tabs and the battery will pop out. Wait two minutes, then push the battery back in. This will change the CMOS settings back to default and reset the Gateway BIOS password. Replace the panel and cords. Turn on the PC and enter the BIOS menu by pressing F2 repeatedly to create a new password. To bypass creating a BIOS password, boot to Windows normally.
Then everything will be just fine.
Thanks.
May 13, 2011 | Sylvania G-Netbook
How to I reset the bios password,on my LT2021u?
If you know the bios password, then change it in the bios menu,if you don''t know the bios password, then clearing the cmos battery should work. You will need to disemble your netbook apart until you can get to the motherboard, there you should see a baterry of a nickel size and take it out and back it, resemble your netbook and you should be good to go.
Here is a link that may help you out too. http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
Jan 30, 2011 | Gateway LT2021u Netbook
Gateway mt6728 recovery boot disk
Nov 29, 2009 | Gateway MT6728 Notebook
Computers & Internet Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
