Question about Refrigerators
How do i remove drawers from bottom of maytag refrigerator model mff2258vew2
Trying to get to back panel to remove and check for leak in drain pan or lines. water draining onto kitchen floor
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Http://www.searspartsdirect.com/partsdirect/user-manuals/2155/MFF2258VEW2-Maytag-Parts-REFRIGERATOR-manual
Open this site and go to page 10, it has detailed instructions on removing the bottom drawer.
Posted on Jan 21, 2013
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
  • 163 Answers
SOURCE: Water is leaking in on the refrigerator shelves.
your drain is clogged,take your back panel off and use a hairdryer until all ice under coils is gone.you will know when your drain unclogs water will flow.pour small amount in drain and make sure it flows.turn temp.control off before doing this.
Posted on Mar 20, 2009
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
Refrigerator sub zero 736 TC water leaking under vegetable drawer
Usually from plugged evaporator drain tube.
remove all the drawers and unscrew the frame that holds the drawers. Free the the drain tube (need to unscrew the clamps that hold the tube to the back wall). Pull it up from the bottom hole where it drains into the pan and free it from the top drain pan. Most likely it\'s plugged with crap and fungus and yecchy stuff. Clean it out and reinstall it.
Jul 09, 2014 | Sub-Zero 650 / O Bottom Freezer...
I have a Maytag Plus Refrigerator, Model # MFF2258VEW2. The freezer section is a pull-out on the bottom with the side-by-side 'suicide-doors' on top of the fridge portion. The top 2/3 portion of the fridge...
Here is a MFF2258VEW2 Tech Sheet W10279337 I want you to try to place your refrigerator into self diagnostics to see if that will point to the problem. I want you to see if the=> W10196393 Damper Control Assembly is opening and closing properly. Also if there is a thermistor that may be defective it also will send the wrong signal to the auto damper. The air damper is what regulates temperatures in the fresh food section by opening and closing to regulate temperatures. I am here should you have questions, Thanks Sea Breeze
MFF2258VEW2 Parts Manual
Aug 28, 2013 | Maytag 22.6 cu. ft. Side-By-Side...
How do i remove the drawers from maytag model mff2258vew2
http://www.searspartsdirect.com/partsdirect/user-manuals/2155/MFF2258VEW2-Maytag-Parts-REFRIGERATOR-manual
Open this link to this manual and go to page 10 for detailed instructions on removing the bottom drawer.
Jan 21, 2013 | Maytag Refrigerators
My Maytag refrigerator is leaking water from under it. Model MFI2569VEM
Just how old your fridge is I don' t know. But is your defrost timer working on your freezer. It should defrost at least once a day. You may want to check out the drain on the bottom of the fridge also. It may be partly clogged up. Then newer models have the coils go over the pan to help evaperate the water.
Aug 05, 2012 | Maytag Refrigerators
Our Maytag MTB1976HRW leaks water under the crisper drawer. The drain has stopped up before but if this is the problem how do we solve this without having to call a repair person?
Open the freezer compartment...
Locate screws on the back wall (from inside freezer compartment)
unscrew and open the back panel.
You will see a hole at the bottom which is the drain hole.
if you feel ice there... then that's the reason... the clog wont let water drain out and it accumulates at the bottom after a few days it leaks out of the fridge.
I used a hair dryer to unclog that hole and within minutes I could see water on the drying pan located below the fridge (which previously was dry)
Hope this helpout......
Jul 28, 2010 | Maytag MTB1976HR Top Freezer Refrigerator
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Water Leak
Sounds like you have a plugged drain line remove thwe bottom drawer and look in the pan see if the little drain hole is frozen over if so use a hair dryer to unthaw and pour a glass of hot water down to make sure it is clear it will go into the pan under the unit if it still wont run free use a Turkey baster to blow out the drain line as something is stuck in it
May 10, 2008 | Maytag MSD2754G Side by Side Refrigerator
Clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Oct 07, 2007 | Refrigerators
Freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
