Question about Shop Vac Vacuums
Looking for replacment power switch
The model of it 92L625C looking for a place where i can buy the power switch for the shop vac vacuum
reddevil6
  • 1673 Answers
SOURCE: Princess III Vacuum
Here is a picture of the dome taken apart, not too hard, take out the 3 screws on top, then the pic should show the rest.
Posted on Mar 13, 2008
RockyNR1
  • 324 Answers
SOURCE: Power Switch
This is not that hard:
1. - remove gasket (it is glued so you may end up damaging it)
2. - remove 4 screws holding baffle
3. - under it you will see 4 more screws holding cap
4. - Four more screws and you will remove cap cover
5. - cut the cable tie, make a note how wires are connected, use flat screw driver to press on the latches holding the switch in while pushing onto the switch OUT. Tension will not let the latches pop back in.
6. - reassemble in the reverse order.
NOTE:
Switch - if you have old style switch installed you will need to push something into each hole next to the wires to release them. There is a cooper lip in each hole that you have to bend a bit to release each wire. Installing new style switch (with 4 wires) - attach one power cord wire to one blue switch wire and another to another blue switch wire. Attach one motor and one power nozzle cord receptacle wire to one black and another pair to another black wire.
Gasket - use weatherstripping glue to glue motor gasket back (you can get some in almost any automotive store)
Need parts - visit our store HERE.
No diagrams - sorry. It is Rexair, Inc. intellectual property and we can not use them...
Good Luck
Posted on Mar 12, 2009
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
SOURCE: need switch for a shop vac modle qpl650
I was able to find the exploded part list view for this model on the following link to help in determining the part number for the switch.
http://www.shopvacint.com/parts006.asp
The part number for the switch is 8231900 and I was able to find a number of sites that carried it ranging from $0.88 to $4.99. Then they tack on shipping which cost 10-15$ which is a rack it, however I had to get it so I ordered two switches using the following supplier.
https://www.alexgs.com/_search.php?page=1&q=8231900
Posted on Sep 09, 2010
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
Bypass power switch
You should simply purchase and install a new switch. It's not safe to bypass the switch as when you do, the entire electrical load is placed on the wall prongs when you plug in or unplug the vacuum. Depending on the brand of vacuum, you can easily order parts and replace the switch at a nominal cost.
Nov 08, 2013 | Shop Vac Vacuums
On off switch stopped working 3rd one to do so this one cannot be returned to old ? model QPV10.5b nothing on shop vac site and nothing comes up on Digi-key site really do not want to buy 150.00 vac...
Hi Ashley,
This website has one for the 12/14/16 gallon vacs:
http://www.vacsrus.com/CartGenie/prod-1165.htm
If yours is a different size, write back and I'll see if I can find it for you. Hope the 4th one lasts a bit longer.....
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Mar 30, 2011 | Vacuums
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Craftsman shop vac no power when turn on
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Burned out motor on QPL625 Shop Vac
well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Sep 17, 2008 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Vacuums Logo
52 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
