Question about Fender Music
Fender deluxe has power fluctuations
Power fluctuations
  • 91 Answers
Try plugging into a different receptacle
Posted on Feb 13, 2013
Hot Rod Deluxe
Most likely clipping. This happens when the source DBs are too high for the amp....feeding in too hot.
Jul 17, 2014 | Fender Hot Rod Deluxe Guitar Combo...
Fender Passport pro 500 - speaker static temporary, then goes away. Usually occurs shortly after turning system on.
If this system is still under warranty get it to a warranty service center. This is an early stage symptom of failure with the Power Amp IC. Fender has a good warranty policy on this stuff - 1 to 3 years
If not under warranty you may want to wait until it the problem is more persistent - easier for a tech to fix - unless it IS every time right now. A good tech can identify the issue quickly once "on the bench". My 'gut' feeling is the Power Amp IC when the system is first energizing to full stable power.
Oct 26, 2013 | Fender Passport Deluxe 500watt Sound...
Fender Hot Rod Deluxe Volume Fluctuations. My amp (fender hot rod deluxe) will occasionally have volume fluctuations when I'm playing. The changes usually occur when I've moved my setup from one place...
First thing would be try another guitar with the amp. This will eliminate if it's a problem with the guitar or the amp itself. If the guitar is working properly then check all the tubes to be sure they are all seated into there slots completely. Depending on how much use they have been played it may be a good suggestion to then replace your tube's. Occationally the tubes will start loosing power, making sound fluctuate up and down or distortion sounding static in background noise. You will notice a big difference with newer tube. But remember the bias must be set correctly to match the new tubes so they won't over heat. You can check out youtube for setting the bias. Anyway this is my suggestion and I wish you good luck.
Jan 18, 2011 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I have a brand new fender deluxe combo amp is the preamp in and out usable for an effects loop
Yes you could do that. The preamp output is just a BUFFERED output of the signal sent to the power amp. And the power amp input jack is BUFFERED before driving the power amp. These impedances are neither high or low being in the 1K to 3K ohm range.
The jacks for BOTH are mono jacks so noise pickup is possible if long cables are used. The external effects unit should be well grounded and operate off the same receptacle as your Fender for system safety. Use SHORT audio cables to minimize noise.
ALL the signal will pass through the effects unit when used this way... HOWEVER the internal reverb will still be in this path. You can kill this by turning the reverb control to zero on the Fender.
May 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Power indicator light is red and the system does
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
Oct 17, 2009 | Fender Passport Deluxe 500watt Sound...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
