Question about Garden
MTD SNOW BLOWER WON'T RUN WITHOUT CHOKE ON
    Sergeant:
  • 322 Answers
If it will only run on full choke you have an air leak somewhere
Posted on Jan 23, 2013
5 Suggested Answers
SOURCE: mtd snow blower no start
Thanks for trying - seems ta have been fuel blockage. Ended up adding starter spray directly into cylinder - now it runs!!!! :-)
Posted on Dec 06, 2008
  • 5 Answers
SOURCE: oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
SOURCE: how to adjust a 9460897 mtd snow blower auger
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Posted on Feb 15, 2011
  • 23 Answers
SOURCE: engine starts but won't continue
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Posted on Aug 15, 2011
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
I have a 5/24 mtd 2 stage sniw blower.it runs with a little choke on and augers spinning. But when i hit snow it dies out
if you can only get it to run in choke , then you have some problem that is keeping the proper amount of fuel flowing , id say most likely inside the carb pathways , Ive had great luck cleaning out carbs with some automotive fuel carb/injector cleaner added right to the fuel tank and let it run (even in choke ) after it heats up the cleaning will begin
Nov 22, 2015 | Garden
I HAVE A TROY BUIT SNOW BLOWER WITH A HUAYI CARB . IT WILL RUN ONLY AT HALF CHOKE .I HAVE CARB APART . CAN NOT GET FUEL METTERING JET OUT IAM SURE IT SCREWS OUT. HOW DO I GET IT OUT?
Why do you need to remove the jet
You can & should be blowing brakleen
& air thru all the holes
The fact you need the choke partially closed-- tells you something
Your creating higher air velocity,so check for a vacuum leak
(failed gasket) on intake side
May have a failed head gasket also
Nov 15, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Craftsman Snow Thrower engine spews balck smoke
the choke is stuck so remove the cover and look for the choke to see why it,s not movin
Feb 13, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Engine start to run rough and shot off after 3-4 minutes running
Possible solutions:
You could have water in your gas if so a $3 additive will unfreeze and eliminate this which will cause rough idling. If your carb is clean make sure to let the blower warm up for several minutes, take off the choke as it warms and it will run smoothly. Last if those dont work, adjust your carbs mixture setting screw (when the engine is warm). (and check your oil! Hope this helps.
Feb 04, 2014 | Mtd Snow Thrower 28" 357cc Ohv
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
Mtd 31a 140 062 snowblower won't shut off with key
Here is the MTD Model 140 Manual for the snow blower / snow thrower. You can refer to section 11 for trouble shooting guide..
Feb 03, 2013 | Garden
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
