Question about Gateway FPD 1730 17 in. Flat Panel LCD Monitor
Plug the monitor into computer, the monitor says "no signal input
When I plug the monitor into the computer, the monitor says "no signal input". This is my mom's computer and I took it home to fix it and when I plugged my monitor in I initially had the same problem but I got it took work. Yesterday, I took her computer back to her and that is when I got "no signal input" and I get no picture on her screen. I am wondering if the connection on the back of the desktop is faulty and can I replace just that part, where could I find the part?
The Machine
  • 788 Answers
SOURCE: HANNS-G Model# HX191
Seems like it. Can you see a very faint image of the screen if you hold your nose up to it?
Posted on Jan 11, 2008
TampaNative
  • 778 Answers
SOURCE: Gateway FPD1960 TFT works with laptop, not desktop
Elbtax,
Click start > right click on "My Computer" > Properties > Hardware tab > Device Manager button > Display adapters > Right click on your device and select uninstall and re boot your computer. Windows should pick up your adapter and re configure it automatically. This method should Fixya!
Good luck, and let us know how it goes.
Posted on Mar 18, 2008
  • 152 Answers
SOURCE: Gateway Monitor keeps going black
Alicia, Your monitor digital board is OK. The problem is with the power supply/ Inverter board(s) in back of the LCD/LPD Panel that you look at. You will need to question Gateway to see if they have a swapout program where you send them $30-$60 and your old monitor, and they will send you a refurbished (new cold cathode fluorescent tubes w/inverter board installed ) complete monitor. I'll tell you one thing though. Alicia, Don't feel bad abt this monitor of your's failing. You have joined the club with over 2000 others whose CCF tubes and INVERTER boards have with time now fail to light-up their LCD panels. Yes, there are some companys that do repair of these monitors. Try surfing under CCF tubes or FPD repair, or LCD repair. Yes Alicia, you are dealing with a technology similar to the new type of screw-in light bulbs, only the tubes are thinner and laid flat horizontally across the rear of your LCD panel with a reflecting mirror in back of them. Good luck girl in getting it repaired. I'm louie12fix on fixya or lmistyrel @aol .com North of Chicago 40 miles
Posted on Feb 27, 2009
  • 152 Answers
SOURCE: gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Posted on Apr 03, 2009
  • 109 Answers
SOURCE: no signal message on monitor.
try to check your vga cable..try it with another one..
Posted on May 11, 2010
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Searching for signal
DVI and HDMI are the exact same signal, except that DVI doesn't include the provision for audio. Essentially the problem you're having is that you have the monitor set to auto input rather than HDMI input or DVI input. Setting the monitor to not look for any input you plug in and defining the input should cause the hunting wait to be eliminated.
Nov 23, 2013 | ASUS VK222H Monitor
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
No signal input
Check to make sure the cable that plugs into the computer is in tight and the other end is in the monitor tight.
Remove the VGA cable that goes from the monitor to the computer, and take it out of the computer. Look at the piece that plugs into the computer to see if any of the pins or prongs are bent. If so that could be your problem. Straighten them out with a pair tweezers. It's normal for it to look like some pins are missing. That's the way they are made.
Try another monitor to see if the Video Card in the computer is bad. If it's bad both monitors will get the No Signal Message.
Mar 26, 2012 | Computers & Internet
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
How do i switch my monitor to vga input?
Plug in the VGA cable to the monitor, and to the computer.
The monitor automatically determines which inputs have a valid signal source.
You can also set the monitor's source of video input to VGA, by going to the On Screen Display menu, and the Switch Video Input option.
Here is the User Manual,
http://h10032.www1.hp.com/ctg/Manual/c00834092.pdf
If you have questions post in a Comment.
We'll step by step you through it.
Regards,
joecoolvette
Dec 17, 2010 | HP w2207 Monitor
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Logo
590 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
