Question about Kwikset Ultramax Security - Shelburne" Handleset Satnik
Install a single handleset - Kwikset Ultramax Security - Shelburne" Handleset Satnik
  • 3,904 Answers
Is this into an existing door or a new door. Is there existing cut outs where the lock set goes or is this a blank door?
Posted on Jan 21, 2013
Kwikset thumb plate on handleset is loose and won't work
Remove outer trim, tighten inner trim, put outer trim back. Go to Kwikset.com for full installation instructions for your model.
Dec 31, 2013 | Kwikset Locks & Locksmithing
I have an old schlage door handleset. It is not the one pictured next to this post but that was the closest pic I could find. It has the exterior handle with key lock which locks/unlocks/operates the...
Hi..Please contact the vendor from you have purchase. and replace door handle set or door knobs (knocker). or you can contact to other for new buy as per your requirement. i hope this will help you..
Mar 14, 2013 | Schlage Plymouth" Georgian Entrance...
Weiser deadlatch replacement
Most post style latches will work on these.
Feb 03, 2013 | Weiser Lock Glc9471 K/ai11p Smt 6lr Vb...
How to install single cylinder handleset with lido lever
I'm not sure whether you need instructions for an entry door or an internal bedroom or closet door. So let me steer you to the online site:
Go to :
http://www.kwikset.com/Products/Categories/Door-Levers.aspx
Then "Browse by function" for the appropriate type, then choose the Lido
On the next page, you can click on any Lido finish, the instructions will be the same regardless of finish.
Once you 're on the next page, under the red "Technical Documents" heading, choose "Installation Guide".
It will take a moment to download the PDF file of the installation instructions for you to follow.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Aug 02, 2012 | Kwikset 4 Lido Lh Passage Levers Satin...
I am replacing old Schlage exterior handleset with a new Schlage exterior handleset. How do I remove circle on interior of door?
Some schlage rosettes screw off. They have a special wrench. You might go to a lock shop, and ask the locksmith how to take it off. Other type knobs you pop off with a chisel or knife.
Sep 10, 2011 | Garden
How do I change from LEFT opening to RIGHT opening for the Arlington Lido handle set single cylinder
This web page will take you to the General description of your model:
http://www.kwikset.com/Products/Details/Handlesets/802AN-LIP-L03.aspx
I suspect that this special-order lockset may not be reversible-in other words- specific to right-hand or left hand only.
I therefore urge you to contact Kwikset directly for further assistance. Click on the link found on that page for Customer Support, then "Contact Us"
Any further model information and description that you can provide will be helpful.
Jul 29, 2011 | Locks & Locksmithing
Why won't the door latch extend fully anymore? It extended fully for a few days after being installed.
Why does the interior knob or lever on my front entry handleset sometimes cause the latch mechanism to jam and the exterior thumb press to lock in place?If the front entry handleset is newly installed, the latch mechanism may be binding. If the exterior handleset is left sitting in the bottom of the bore hole through the door, the rectangular spindle that extends through the latch may be somewhat tilted and binding. This can be checked by loosening all screws, slightly lifting the exterior handle, and then tightening the screws before releasing the handle. This may make the spindle more level with the latch and eliminate the binding. If this does not resolve the problem, or the handleset has been installed for some time before the problem occurs, the latch mechanism may be failing and need to be replaced.
May 03, 2011 | Schlage FE365-CAM-ACC Lifetime Polished...
Kwikset arlington handleset needs to be tightned
Look at the most bottom part of the hardware on the inside and see if there is a little round decrotive cover [looks like a button,dime size] and will either will pop off or try unscrewing,once of you should find a single screw which will allow you to tighten hardware or remove.
Please rate.
Mar 14, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Mar 12, 2009 | Top Knobs M826 Door Pull
Kwikset Ultramax Security - Shelburne" Handleset Satnik Logo
89 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
