Question about Miele S548 Bagged Canister Vacuum
On a Miele Champagne model S548 how to replace electric cord reel
Work cord in and out, electric short probably in connector to reel. By pulling cord in or out can make a short connection.
  • Miele Master
  • 18,408 Answers
  • 389 Answers
SOURCE: vacuum not running; do I have to replace the cord winder or just cord?
Typically, the cord and winder are supplied as a unit.  It is possible to fit new cord to an existing winder, but the amount of labour involved will make the job more expensive than simply exchanging the complete unit.  Even if you're going to do the job yourself, it's simply not worth planning to just fit new cable (unless you are a masochist with unlimited time and patience).  Pay that bit extra for a complete unit - you'll be glad you did (or you'll be sorry if you don't!).
Posted on May 27, 2009
SOURCE: Miele vacuum cord reel question
I had to take off the cord reel and clean the contacts inside it. I also bent the contacts out since they tend to wear down after time.
Posted on Jun 07, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Miele S544 Artico just quit working. I took it
Greetings from GoVacuum,
The repair for your model is identical, and no it doesn't cost $500, we sell cord reel for $103. I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel (hopefully from GoVacuum), You may purchase the S500 Series Cord Reel Here; Miele Cord Reel - s500 Series #5240304 .
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner2_bing.gif before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum2_bing.gif bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them.
If this repair guide was helpful to you, please click the four thumbs up icons in the top right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
VacuumRepair
  • 438 Answers
SOURCE: Miele Champagne Vacuum Cleaner Model S548
Greetings from ,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele , no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to your Miele Champagne. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
Posted on Mar 21, 2010
  • 147 Answers
SOURCE: My Miele S548 does not turn on. I am suspecting
heya,
your exactly right. there is probably 2 or 3 screws your missing there.
now getting to these screws is easy. If you haven't already, remove the top filter and the bag door lid.
Assuming you have taken the screw out holding the black control panel out already... you want to remove the black panel with your on/off switch and the cord rewind. Once you have the panel off there are a couple of screws there that are holding you back. once removed, you should have full access to the underneath with the motor and cord rewinder there.
Good luck,
Mark
Posted on Nov 11, 2010
Bounced down a step while on, blew house circuit breaker, now s548 only powers on when on its side
Rickhan,
I would recommend taking it to a Miele dealer and let them repair it. It can get rather tricky trying to put those back together. I speak from experience and I work at a Miele dealer and I leave them for the other repair tech.
Jul 04, 2015 | Miele S548 Bagged Canister Vacuum
My Miele S548 does not turn on. I am suspecting power cord contact inside. I am pretty good at disassembling electrical equipments including TVs and laptops. Not being able to open the vacumm canister...
heya,
Good luck,
Mark
Nov 11, 2010 | Miele S548 Bagged Canister Vacuum
Meile red star
Yes, this very well could be a problem with the cord reel, especially if it happened all of a sudden. There's a few ways that you can diagnosis this problem yourself. First make sure the cord is all the way reeled into the vacuum. Next find an outlet that's close, and only pull out enough cord as you have to, to be able to reach the wall outlet. After you've plugged the machine into the wall, use one hand to slowly pull more cord out of the vacuum, and use the other hand to continuously turn on and off the vacuum pushing the foot pedal that controls the main switch. Slowly pull the cord out, and turn the vacuum on and off, on and off, on and off.
At any point while you were doing this did the vacuum come on, even for a very short time? Did it even make a noise like it was trying to start? If you heard a noise, or the vacuum even came on for a time, then this definitely indicates that you have a bad cord reel.
If it didn't make a noise or come on, you still may have a cord reel problem, but you'll need to take the machine apart to further diagnosis it at this point. A simple continuity electrical tester will be needed to test the cord reel.
Here's a very detailed repair instruction that I left for a similar model Miele on Fixya already. The model that you posted the repair under is a Miele Red Star which is an S314i, the model I repaired the cord on was actually a S514. The cord repair on both of these models is identical however, except your Red Star actually has two screws that need to be removed from the variable speed control box, the S514 only has one. Otherwise, it's almost completely the same repair. If you need to purchase a cord reel for your Miele, here's a direct link to the Miele S300 series cord reel that goes with your Red Star:
http://www.govacuum.com/miele-cord-reel-s300-series-06777540.html
Even better, if you purchase the cord reel from GoVacuum, you have 60 days after the purchase that you may return the cord reel to us if that wasn't the problem (we do test all the returns to make sure that they weren't damaged when being installed), and as long as the cord reel is returned undamaged, we give you a full refund, we don't believe in restocking or shipping fees. Better yet, we even include a return label with every order that you may use for free to avoid return shipping charges.
If you find that the cord reel is not the problem, that can only leave one of three things; the switch, the motor, or the pc control board that's on your motor. In 10 years of fixing Miele vacuums however, I can safely bet that it's your cord reel.
Anyways, here's the link to step by step instructions on how you can remove the cord to test it, as well as replacing it. If you have any questions, please feel free to use the Clarification or comment form here on Fixya, or contact us by phone. If this was helpful to you, please be so kind and rate my repair as helpful by clicking the thumbs up icons at the top of the page. Thanks so much!
How to Test & Change a Miele Cord Reel:
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
Chris J.
GoVacuum
Apr 06, 2010 | Miele Red Star Bagged Canister Vacuum
Miele just stopped working?
When a Miele canister just stops working all of a sudden, it's usually a pretty clear indication that either you have a bad cord reel, or a bad switch. I would say that in 60% of Miele repairs that I do with this problem, the cord reel has gone bad.
One easy thing that you can try to see if the cord is bad, is put one hand on the on/off switch, and the other hand grab the cord (making sure it's fully retracted inside the canister). Now pull the cord out slowly with your one hand, while continously turning the switch on / off, on / off. Keep pressing the switch on and off while pulling on the cord. Usually if the cord reel has gone bad, then you may hear the vacuum attempt to start, or even turn on while you're pulling on the cord. The cord reels in Miele use a metal spring inside that makes connection with the rest of the vacuum. Over time this spring will start to loose it's strength, and eventually will get so bad that it no longer makes contact with the rest of the vacuum. By pulling the cord out slowly and pressing the on / off switch, a lot of the times the spring will make connection somewhere, and the motor may turn on temporarily.
If this happens, this indicates your cord reel needs to be replaced. I have done a detailed repair here on Fixya on how to replace the cord on a Miele canister vacuum that you may read here;
If you can't get the vacuum to turn on at all, this can only mean a few things. First the cord reels spring is gone completely, and wont make any connection with the rest of the vacuum, and you'll still need to replace it.
It also can mean that just the plug that plugs into the wall is bad, is your plug bent, or no longer straight on either prong?
It can also mean that your motor has gone bad. This however is usually the least likely of all the problems. The Miele motors are almost bullet proof, and typically last 20 years. I can count on one hand the number of Miele motor replacements I've ever done in 10 years of fixing vacuums.
I can try and help you diagnosis this further if my suggestions didn't help you. Please use the clarification request that you see here on this page to ask me a question. Please just let me know what happened when you tested the cord out as I suggested above. I really hope this was helpful to you. If you found this to be helpful, please be sure to rate the repair as helpful to you by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele S318 Bagged Canister Vacuum
Miele Champagne Vacuum Cleaner Model S548 I was using the vacuum as normal, moved locations so I plugged into another outlet & suddenly there was no power to the vacuum! I tried it in several other...
Greetings from ,
Thank you so much,
Chris Jones
Feb 09, 2010 | Miele Blue Moon Bagged Canister Vacuum
Thank you so much,
Chris Jones
GoVacuum.com
Jul 06, 2009 | Miele S544 Artico Bagged Canister Vacuum
Meile S548. It work turn on expect when I fiddle with retractable cord. Even then, it's prone to stop again. The machine is relatively new and shows no cord wear.
you have a bad cord reel. the cord may look fine but its the contacts inside that have gone bad. i have had some luck with simply adjusting the contacts but probably need to replace the cord reel.
Sep 28, 2008 | Miele Vacuums
Was using my Miele Champagne vacuum, powered down, changed the bag, and now I have no power. I checked to make sure all lids were securely closed, still no power. Checked to make sure outlet was working,...
Most likely the cord went bad, one side of it opened up, you will have to replace the cord reel asm. if this is the problem, Could also be a switch, electronic control or the motor.
Aug 10, 2008 | Miele Vacuums
Power to power carpet head
it sounds like the spring on the cord reel let go. difficult to reinstall. it may have been broken already and that is why it came off. it is rather meticulous trying to work on a cord reel. many can't be disassembled without breaking
Aug 09, 2008 | Miele S548 Bagged Canister Vacuum
Miele S548 Bagged Canister Vacuum Logo
347 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
