Question about Texas Instruments TI-83 Plus Calculator
Wont turn on
I've gone thru all the steps I can find on google. It just wont turn on with a new set of batteries.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Just which steps have you gone through?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we can go to the next step.
Posted on Jan 21, 2013
Rx 1000 wont power up even with new battery
This problem is caused by the 'step' inside the battery cover which prohibits the tip of the battery from contacting the nipple inside the cover. I fitted a thin piece of aluminium strip (20thou) and the rangefinder works perfectly now. Make sure you dont bridge-out the +ve to the neutral (i.e. battery casing).
Oct 23, 2012 | Leupold RX1000 TBR Rangefinder
How to change gmail password?
  1. Click the gear icon in the upper right, then select Settings.If you're on a mobile device, switch to desktop view for the full list of settings.
  2. Open the Accounts and Import tab.
  3. In the 'Change account settings' section, click Change password.
  4. In the new window, enter your current password and your new password.
Hope that helps!
Source: http://support.google.com/mail/bin/answer.py?hl=en&answer=6567
Aug 21, 2012 | Google Computers & Internet
Problems with google.com - not in English
try going to www.google.com/ncr
that should prevent google from redirecting from the .com website.
Jun 09, 2012 | Computers & Internet
The charger that comes with Homelite 24v mower is crappy. I've gone thru 3 of them. What's a better alternative?
I have used a DieHard portable battery charger (model 200.71222) for several years to recharge my 24-volt, 18-year old Craftsman mulcher, model 315.370270. This is after the on-board charger died. I just disconnect the link between the two 12-volt batteries and remove all other battery connections. Then connect the charger leads to the positive and negative terminals on one of the batteries before plugging in the charger. I put the settings on the charger at conventional low maintenance and 2 amps. Charge one battery and then the other (assuming you have two 12-volt sealed lead acid batteries like my mower). I use binder clips 530-t.jpgfrom an office supply store to hold the battery wires on the terminals when I'm mowing...makes it simpler to remove and reattach for charging instead of the nut-and-bolt connectors that came with the mower.
May 14, 2012 | Garden
Wont reset wont turn on
You could open up the back and disconnect the battery for a minute and reconnect. The battery is the big gray in the back with the white/red/black cable. I got mine to load up, but it then froze at the Cruz logo. I've seen this problem a lot with the readers, maybe it has something to do with Google changing the App store to it's new name and these readers will not support it.
Mar 05, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
We installed a honeywell RTH110B thermostat last year. It was working fine. Since then I have changed the batteries. Now I can't get any display. The batteries are good, I've tried a couple of...
From your description the only possible thing it could be is the thermostat. The screen has gone bad. Replace thermostat.
Hope this helps.
Sep 19, 2011 | Heating & Cooling
Why won't my browser allow me to use facebook? I've tried loading it with google chrome, internet explorer, & firefox. None of them work. When I try loading it in google chrome it gives me...
Hi, If this problem is still occurring for you and is only specific to Google Chrome, can you try clearing your browsing data to see if that helps? To clear your browsing data, follow these steps:
1) Click the Wrench menu in the upper right corner
2) Select "Tools"
3) Select 'Clear browsing data'
4) Ensure that check boxes for 'Clear browsing history' and 'Empty the cache' are selected
5) Click 'Clear browsing data'
I hope this helps. eibraz
Aug 03, 2011 | Facebook Social Network
First, 3 days ago my alternator went bad and immediately ran the battery dead, and of course it went out in excessively hot texas weather here. I've spent the last 2 days replacing and checking every...
wow,, your a die hard , you must love that car!! ok,, first,, yes earth is the ground, ok I can't write all I need to write because this feed doesn't allow for me to write that much, But you can read it here, if you follow the steps, and do whats listed, you might be able to finally locate that problem, always make sure you have really good grounds first of all,, I wish you luck, let me know how it turns out, or if I can help you anymore heres the link http://en.allexperts.com/q/Chrysler-Repair-807/Battery-drains-overnight-find.htm it works the same with all vehicles, I just came across it one night while trying to find something else
Jul 10, 2011 | 1997 Pontiac Grand Am
My turn signal lever wont click back to original spot after I've made a turn and if I click it down to turn left, I have to hold it down while I make the turn
Dear,
Your click lever has gone damaged mechanically get it replaced with the new one.
this the only solution for that.
thanx
May 18, 2011 | 2006 Chevrolet Malibu
Texas Instruments TI-83 Plus Calculator Logo
46 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
