Question about Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair
Ford heater blows heat then goes cold temp goes up rev enginge gage goes down
  • donna magers Jan 21, 2013
    changed thermostat
    and heater core
    New Friend:
Low coolant or faulty thermostat
Posted on Jan 21, 2013
    thermostat and heater core replaced losing coolant but no steam out exshaust or change in oil color
Heat goes in and out and the temp gauge goes up and down
Your temp sensor has nothing to do with your heater. The temp sensor needs coolant in order to work properly. So first check the coolant level because if it is low your heater will act the way you describe. Once the coolant gets low enough the heater will blow cold. Another possibility is the radiator cap. After the engine has warmed up it expands when it cools down it contracts. As it is contracting if the cap is weak air can be drawn into the system and cause air pockets to form and will cause the same problem
Feb 09, 2013 | 2000 Pontiac Grand Prix
Heat gauge goes way up,then by reeving motor it will go down.blows cold air
Check out related help links with solutions to troubleshoot the problem:---
Click the link below:---
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
Toyota 4Runner: Temperature Gauge Sensor http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark? http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
------------- No heat on Oldsmobile Silhouette? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Temperature gauge does not move and no heat when heater is ON? http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
Temperature gauge keeps fluctuating up and down close to red? http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
----------- Temperature gauge on the dash quit working on Pontiac Grand Prix? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Dodge neon gauges not working? http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
1992 Lexus LS400: Engine overheats, Antifreeze out of reservoir and heater Blows Cold Air? http://whatisbyme.blogspot.in/2012/05/1992-lexus-ls400-engine-overheats.html
These details will help.
Thanks.
Nov 22, 2012 | 1997 Ford Taurus
1998 Toyota Camry 4 cyl.only blows warm air from heater when car is unning for say ten min. When I start driving the temp gage goes down to cold and blows cool air, no heat. I changed thermostat and...
Your radiator cooling fan will only come on when the engine temp has reached the point where it needs to have air forced through the radiator and thus bring engine heat back down to safe operating range. If your heater is not working check to make sure the fresh air vents aren't stuck open (are the controls stiff or not going all the way across?) check also that the heater shutoff valve lever which is usually situated on the firewall at the rear of the engine and can be found easily by tracing the hoses back from the thermostat housing aren't bent and/or seized up.
Apr 08, 2017 | 2000 Toyota Camry
I have a 1993 Acura Ledgend. For some reason my heater does not continue to blow hot air, it does for a few minutes and then begain to blow cold air. It does this often now. It works and then it blows cold...
first check to see that you coolant level is full, check it after the engine has cooled down,so there is no pressure in the system. otherwise you possibly have a head gasket in the early stage of failure
Nov 30, 2009 | 1993 Acura Legend
Temp Gage
sounds pretty normal. its not overheating but if you still want to do anything try replacing the thermostat and see it it changes
Jan 28, 2009 | 1991 Mazda Protege
No Heat in 99 Taurus
Just finished fixing my daughters 1999 taurus heat. It would blow warm only when running down the road. At idle it blew cold. I started with replacing thermostat, and water pump because they are the easier fix. Still did not help. Then I replaced the heater core. A daunting job but not that hard to move the dash slighly out of the way to replace. There is a good write up at tarusclub.com. After that, heat was better but at idle, it would still blow cool sometimes. Researched and found answer. Park car on the steepest hill you can find with front of car up. Start car and take off reservoir cap. Let car warm up and keep rpms about 1500. After a while the fluid will come running out of the car and all over the place but it will bring air bubbles with it. Reduce rpm, add more fluid and repeat about 3 times. It will make a mess but after that, the heater works perfectly. We get heat long before the temp gage indicates any and it never blows cold unless you lower the temp.
Nov 21, 2008 | 1999 Ford Taurus
My engine keeps blowing out the anti freeze through the fill tank overflow. I have a 2004 Super Duty 6.0 turbo.
start you truck. let the temp gage get to where it will start blowing the antifreeze out. than turn your heater on full blast. if the temp goes down and the water doesn't come out than you need to change you thermostate.
Aug 02, 2008 | 2005 Ford F 350 Super Duty
Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair Logo
74 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Bill Boyd
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
