Question about Woods Hardware & Accessories
I have a timer that goes on but does not go off
The model is 59017
  • 7 more comments
  • Joseph Wolfe Jan 21, 2013
    I have the manual and followed the wiring instructions. The manual also states that if the timer is nonfunctioning that I should switch the bloack leads. I will try this but the timer is actually working, but not correctly.
  • Gene Haynes Jan 22, 2013
    So the dial is rotating? And the pins are set correctly? And current time is set? And slide switch is moved to timer position?
  • Joseph Wolfe Jan 22, 2013
    I am not sure if the dial is rotating. The pins are set correctly. The current time is set. Thbe slide switch has been set to the timer position. I am switching the black wires shortly.
    If dial is NOT rotating around each 24 hours, then reverse red and black wires, and that should work.
    I have one of these timers installed to control water heater.http://waterheatertimer.org/images/IMG_2... The timer has worked fine for several years, but I expect the small motor that rotates dial will will stop working at some point.
    This could be a motor problem but my timer never worked from the day it was installed.
    I believe timer is wired wrong. Please follow step-by-step instructions for single-pole timer:http://waterheatertimer.org/How-to-wire-...
    I appreciate everybody's time and help but I am going to give up on getting this done cforrectly. I have already paid an electrician to wire it and his work also did not do the job. I guess it is not in the stars that I should have a working tijmer.
    Geeze. Turn off the power. Pull out the timer. Tell me how the wires are connected. The timer is good, it is wired incorrectly, and you can fix it right now. I'm here right now.
  • Woods Master
  • 5,245 Answers
1) Copy following link to identify timer, see how to set pins for on-off functions, and see how to wire timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
http://waterheatertimer.org/How-to-set-timers.html
2) If this is new timer, then return for exchange or warranty.
If timer is older than 1 year, then select another similar timer
http://www.colemancable.com/contact-us/technical-support/
3) Add a comment and describe age of timer, wiring, and other related information.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jan 21, 2013
How do I reset Woods 59017 mechanical timer
There is no reset for 59017 timer.
Check if slide switch is set on timer
If timer is not rotating, then check circuit breaker, check wiring, replace timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Oct 15, 2014 | Woods 59017 Mechanical Repeats Daily Wall...
Describe model 59017/ how to program. Does it work with halogen bulbs?
Question is not 100% clear.
1) Question posted under Woods 59018
59018 is programmable digital timer which does not show 'electronic ballast' or 'halogen' as a load capability.
http://waterheatertimer.org/pdf/59018-sell-sheet.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
2) Question asks about Woods 59017
59017 is 24-hour analog timer which will work for all loads including CFL and halogen loads
3) Add a comment for more help.
For example Aube programmable timers will work with CFL and halogen
http://waterheatertimer.org/Aube-timers-and-manuals.html
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
Find the time now arrow to reset
1) Question posted under Woods 59017 analog timer.
2) On the Woods 59017, the 'arrow' or triangle is a hollow triangle shape on inner timer dial. It points at the 3:00 position.
Manually rotate dial until current time lines up with arrow, arrowhead, or triangle.
3) On other analog timers, the time-now 'arrow' is usually small dark-colored triangle or arrowhead located on stationary part of inner dial.
4) Open following link to see how to set and use analog timers by experimenting with each feature.
Plus images of time-now arrowhead or triangle.
5) Take a moment and rate answer:
Sep 04, 2011 | Woods 59017 Mechanical Repeats Daily Wall...
I have the 59017 Mechanical. I set the pins and turned on in timer mode. It comes on at specified time, goes off after specified time, but then does not come on again the next night.
I don't have repair for defective timer:
If Load and Line wires are reversed, that could explain problem. Reverse timer red and timer black wires. Symptom of this problem: the clock dial stops rotating after tripper pin.
Troubleshoot run-through:
1) Use fingers and manually rotate timer dial several times and watch if Load turns ON-and-OFF
This will tell you if load is operational, and pins are set correctly.
2) Set slide switch to Timer.
3) Make sure timer is wired correctly. This timer needs neutral wire to operate clock motor. Open following link to see illustration and read about wiring. Line and load wires must be correct.
http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
4) Check that wire nuts are attached very tight and there are no loose wires.
Additional resource:
Aug 21, 2011 | Woods Mechanical Inwall Timer 59017
Hi, we just got a new woods 59017 timer, and the dial turned until it turned off, at the point that we indicated, but after it turned off, the dial remained stuck in its place and will not turn any...
You have new 59017 single-pole in-wall 24-hour timer with tripper pins located on dial.
Timer is heavy duty and will handle up to 2500Watts 1 HP, including anything typically controlled by 15-20Amp light switch: incandescent, florescent, CFL, motor, pump, AC, whole house fan, etc.
http://waterheatertimer.org/images/Woods-59017-mechanical-timer-300.jpg
When timer is wired correctly, timer dial rotates no matter which position slide switch is set to.
Your dial rotated correctly and turned lamp ON, and rotated correctly until lamp turned OFF, and then stopped rotating.
This implies loss of power.
Check circuit breaker.
Check for loose wire on timer installation.
If wiring checks out, then timer is suspect. Replace different switch with suspect timer, and see if timer works on different Load.
Aug 08, 2011 | Woods Mechanical Inwall Timer 59017
Hello! I have a 59017 timer, and this is my problem: When I put the timer in Timer option, If I have all the pins in off, the timer run ok, but if I put one Pin in On mode, The timer run ok but when find...
You don't say if this is new timer installation.
Or if timer was working before and suddenly stopped working.
I also own Woods 59017 timer from Home Depot.
1) New timer installation:
Open following link to access manual and read wiring instructions.
2) Old timer that stopped working:
If timer dial does not rotate, then the timer is broken, does not have power, or is wired wrong.
If timer stalls when it gets to a pin, then the clock motor has gotten weak, and is overheated and will stop working.
3) Buy new GE 15070 timer from Home Depot for $18
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
4) Buy new Woods 59017 at Amazon for $11 plus shipping
http://www.amazon.com/Woods-59017-Mechanical-Repeats-Switch/dp/B002MO3LWQ
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 03, 2011 | Woods Mechanical Inwall Timer 59017
The dial doesn't advance in time but the light works when I manuallly move the dial
You posted under Woods 59017 timer.
1) If this is a new installation, then timer is wired incorrectly.
White wire is probably wrong, white wire is connected to Neutral wire or ground wire so timer motor operates.
Open link to identify product for sure and read detailed wiring instructions.
2) If timer worked in the past, and stopped working, then it sounds like timer has gone bad.
Buy another 59017 from Home Depot, and then take defective one back with receipt.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 22, 2010 | Woods 59017 Mechanical Repeats Daily Wall...
Hardware & Accessories Logo
37 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
