Question about Yamaha AV-1 Shelf System
I need a yamaha av-1 system connector from tcd av-1 from sw av-1
Yamaha cinema station av-1. i need the mains system connector cable. connects tcd -av1 to sw - av1
2 Suggested Answers
SOURCE: i need the connector cable
The connector appears to be an 8-pin mini-DIN connector. http://en.wikipedia.org/wiki/Mini-DIN_connector#8-pin
I got one from an old Apple system, but I haven't been able to get my TCD-AV1 to power on. It may be due to another problem, though. Hope this might help!
Posted on Apr 02, 2011
Tdm900 backfires
Hi, Alan and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
hanging idle
Used Review Yamaha TDM 850 900
Yamaha 2002 TDM900 Service Manual
OEM parts for Yamaha
YAMAHA TDM900 Owner Manual
Jan 31, 2017 | 2004 Yamaha TDM 900
1999 yamaha wr400 backfires running rough
Hi, Anonymous and the usual suspects are:
YZ400F backfires wont idle dies YZ 400 426 450
WR400 backfiring
YAMAHA WR400F Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-wr-owners-manuals
Nov 17, 2013 | Yamaha Motorcycles
Yamaha xs850 backfire
Viewing thread Problems With Running Backfire
1980 yamaha 850 backfiring Motorcycle Forum
http://biobug.org/motorcycle/xs850/Yamaha-XS70-XS850-Service-Manual.pdf
Yamaha XS850G Owner Manual
How to stop my 04 yz 250f from backfiring
6. Faulty spark plug cables, leaking or broken, internal damage.
Dirt Rider Magazine
YZ250F backfire
YAMAHA YZ250F Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 04, 2012 | 2004 Yamaha YZ 250 F
Yamaha r6 53 reg cuts out when hot missfire flames from exhaust
Yamaha R6 2001 Cuts out
R6 motorcycle cylinder misfire power loss fault finding spark check...
2003 2004 Yamaha YZF R6 Service Manual R6 Moto Data Project
Mar 10, 2012 | 2003 Yamaha YZF-R6
I need the connector cable for a yamaha tcd av1 and need a part number please any help is appreciated
Feb 19, 2011 | Yamaha AV-1 Shelf System
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Play station 3 and tv
The ilo dtv 2784 can be hooked up to the PS3 a few different ways actually!
1st - It can be hooked up through "component" cables. This is the red, green and blue connectors (video) with a red and white connector (audio). You would need to buy the component cable specifically for the PS3. This would be the "best" quality, and this link is just to show you what it looks like (they can be purchased at almost any store that carries electronics.
http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1238741997&sr=8-1
2nd, you could hook it up with "composite" cables, which are the standard cables that most of us have used at one point or another. It is the "yellow" connector (video) with the red and white connectors which are (audio). This cable will not give you as good as quality, but it is cheaper if money is an issue.
http://www.amazon.com/AV-Composite-Cable-Sony-PS3/dp/B000SEU92W/ref=sr_1_1?ie=UTF8&s=electronics&qid=1238742142&sr=1-1
Please don't forget to rate my answer "FixYa" if this answers your question. Bye pannbjoosten!
Apr 03, 2009 | Video Game Consoles & Games
Sub digital coax connection
You will need to get a y connector and split the sub out signal between the one it came with and your additional sub. The connector you need is an MFF, (1-male, 2- female) RCA type.
Good Luck,
BB
Jan 06, 2009 | Yamaha HTR-6130 Receiver
Connecting ps3 to cinema system
There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
Audio connections from best to least go in this order:
1. HDMI (digital)
2. Fiber optic (digital)
3. Coax - Digital (digital) <--- The one you want to use.
4. Component (analog)
5. RCA/AV (analog)
Video connections from best to least go in this order:
1. HDMI (full HD digital)
2. Component (Blue, green, red, white, red - HD analog)
3. S-Video
4. RCA/AV (Yellow, white, red)
Good luck!!
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Yamaha AV-1 Shelf System Logo
96 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
