Question about Maytag Washing Machines
How to remove brake - Maytag Washing Machines
  • Maytag Master
  • 17,129 Answers
Get tips from removing the drum and accessories: click on DRUM
Posted on Jan 21, 2013
How to remove and clean and replace the rear brakes on a 2008Toyota yaris
REMOVING REAR BRAKE DRUM SUB-ASSEMBLY
1. Release the parking brake and remove the rear
brake drum.
If the rear brake drum cannot be removed easily,
do the following:-
2.Remove the hole rubber and insert a screwdriver
through the hole into the backing plate, and hold the
automatic adjust lever away from the adjuster.
3.Using another screwdriver, contract the brake shoe
by turning the adjuster.
4. Take out the brake drum from the flange.
5. remove the shoe hold down spring cup, shoe hold down spring, pin and front side brake shoe.
6. Remove the tension spring. Remove the shoe return spring from the rear brake shoe and remove the parking brake shoe strut set.
7. Remove the shoe holding spring cup, shoe hold spring, pin and rear brake shoe.
8. separate the parking brake cable.
9. Remove the automatic adjust lever tension spring and remove the automatic adjust lever.
10. remove the C-washer and remove the parking brake shoe lever.
NOTE: Do not use any solvent like gasoline to wash the brake parts.
Always wear safety goggles and mask before using compressed air.
Dec 28, 2013 | Cars & Trucks
Tip
How to replace AUDI front brake disc
Atention!!!
Don't disconnect any brake line from caliper!
Don't disconnect any ABS sensor!
For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow: 1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose! 2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper. 3. Now you must thoroughly clean the brake calipers (free of grease). 4. Remove outer brake pad from brake carrier. 5. Pull inner brake pad out of brake caliper piston. 6. Remove brake carrier from wheel bearing housing (two ribbed bolts). 125 Nm 7. Remove brake disc from wheel hub. 8. Install brake carrier on wheel bearing housing. Tightening torque for two ribbed bolts = 125 Nm. 9. Check up the brake fluid level on the reservor, and emptying if neccessary! 10. Push piston back into brake caliper housing. 11. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward). 12. Install outer brake pad into brake carrier. 13. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm. 14. Install both caps. 15. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!! Check brake fluid level and top up if neccessary!!!
on Dec 18, 2009 | Audi A4 Cars & Trucks
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
Jan 25, 2011 | 2007 Toyota Camry
How can I change the rotors and brakes on a 2006 Cadillac?
Front brake
Step 1: Identify Front Disc Brake Components
Front Wheel Drive Brake Assembly
Most front disc brake components include: brake rotor, brake pads, brake caliper, caliper mount and brake flex hose. Brake service usual occurs between 20,000 and 40,000 miles depending on driver habits, road conditions and brake pad/ rotor materials used.
Step 2: Remove Brake Caliper to Replace Pads
Removing Brake Caliper Mounting Bolts
Locate primary caliper mounting bolts; apply wrench pressure counter-clockwise (When looking at the head of the bolt) to remove the bolts, upper and lower. Make sure the bolt threads are in good shape and replace if necessary.
Step 3: Remove Front Brake Caliper
After removing the primary caliper mounting bolts lift the brake caliper off of the rotor and then tie or secure to the side, being careful not to bend or kink the brake caliper flex hose. Thoroughly inspect brake caliper and brake hoses for leakage, cracks or chaffing and replace as needed. Next remove the brake pads (If not mounted in the caliper) and secondary caliper mounting bolts. Notice how great protective gloves work, most technicians use them on the job today.
Step 4: Remove Brake Pads
Remove Front Brake Pads
Once the brake pads have been removed, make sure if there is anti rattle hardware to transfer to the new brake pads. Some brake pad manufacturers will include the proper lube (Caliper slides) and anti-rattle hardware to ensure proper performance of their product.
Step 5: Remove Caliper Mount
Remove Caliper Mount Bracket
Finish removing secondary caliper mount bolts and remove caliper mount. Note: clean and lube caliper slides and pad friction surfaces of all foreign material or build-up.
Step 6: Remove Brake Rotor
Remove Brake Rotor
With the caliper mount out of the way you can now remove the brake rotor. Sometimes it can get stuck so you may need to tap it with a hammer or use penetrating oil to free it up. Some manufacturers use small screws to hold the rotor on as well. Clean and inspect wheel studs, replace if any are damaged. Also clean bearing hub rotor mount surface to ensure the proper mounting of the new brake rotor. Inspect the ABS sensor wheel for cracks or damage and replace as needed.
Step 7: Depressing the Brake Caliper
Resetting Brake Caliper
To install the new brake pads you must retract the brake caliper piston. Remove the master cylinder lid or open the brake caliper bleeder screw to allow excess brake fluid to be released if necessary. Install C clamp tool and gently tighten clamp until caliper piston is fully depressed. Note: use old brake pad to protect the caliper piston. Close the bleeders once the piston is retracted completely
Step 8: Installing New Brake Rotor
Install Brake Rotor
Install new brake rotor, the new rotor is manufactured with a protective film over the rotor to keep it from rusting, remove protective film with brake cleaner before installing; also after the brake job is complete you may experience a small amount of smoke from the rotor when first used. This is normal and will go away after the first couple of uses.
Step 9: Installing New Front Brake Pads
Installing New Brake Pads
Reinstall the front brake caliper mount, and then install front brake pads. Make sure the pads are seated properly in the caliper mount; it must be a close fit to work properly..
Step 10: Reinstall Front Brake Caliper
Re-Install front Bake Caliper
Reinstall front brake caliper and reinstall caliper-mounting bolts, recheck all mounts and mounting bolts. Check the caliper slides to be sure there is no bind and that the caliper moves freely back and forth on the caliper slides. Bleed brake system per manufacturer's specifications to relieve any air trapped in the system. Before driving the vehicle, push the brake pedal down and let it up slowly, repeat until normal brake pedal operation resumes, this operation is forcing the brake pads to travel to the brake rotors.
Dec 18, 2010 | 2006 Cadillac STS
How do you get the capierer pin off to put front brake pads on my Mercury Sable LS?
Section 06-03: Brakes, Front Disc 1999 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478) . Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120) , front disc brake rotor shield (2K004) or front wheel knuckle (3K185) .
  1. Remove rear brake pin retainers (2N386).
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125) . Do not pry directly against metal caliper piston or damage will occur.
  1. NOTE: To prevent damage, do not allow disc brake caliper to hang by the front brake hose (2078) .
    Position disc brake caliper out of the way.
  1. Remove inner outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate .
  1. Inspect both rotor braking surfaces. Minor scoring or buildup of lining material does not require machining or replacement of front disc brake rotor.
remove the 2 pins, #10 in pic. Usually has a dust cover over pin accessopening. Usually torx haed or hex head bolts (pins).
Nov 12, 2010 | 1999 Mercury Sable
How do I replace the ear brakes?
Bonneville, LeSabre, Park Avenue 2000-2005
Brake Caliper - Removal & Installation
CAUTION Dust and dirt accumulating on brake parts during normal use may contain asbestos fibers from production or aftermarket brake linings. Breathing excessive concentrations of asbestos fibers can cause serious bodily harm. Exercise care when servicing brake parts. Do not sand or grind brake lining unless equipment used is designed to contain the dust residue. Do not clean brake parts with compressed air or by dry brushing. Cleaning should be done by dampening the brake components with a fine mist of water, then wiping the brake components clean with a dampened cloth. Dispose of cloth and all residue containing asbestos fibers in an impermeable container with the appropriate label. Follow practices prescribed by the Occupational Safety and Health Administration (OSHA) and the Environmental Protection Agency (EPA) for the handling, processing, and disposing of dust or debris that may contain asbestos fibers.
Inspect the fluid level in the brake master cylinder reservoir. If the brake fluid level is midway between the maximum-full point and the minimum allowable level, no brake fluid needs to be removed from the reservoir before proceeding. If the brake fluid level is higher than midway between the maximum-full point and the minimum allowable level, remove brake fluid to the midway point before proceeding.
  1. Raise the vehicle and suitably support.
  2. Remove the tire and wheel assembly.
  3. Pull down on the front park brake cable.
  4. Remove the front park brake cable from the park brake cable connector.
    NOTE When using a large C-clamp to compress a caliper piston into a caliper bore of a caliper equipped with an integral park brake mechanism, do not exceed more than 1 mm (0.039 in.) of piston travel. Exceeding this amount of piston travel will cause damage to the internal adjusting mechanism and/or the integral park brake mechanism.
  5. Install a large C-clamp over the top of the brake caliper housing and against the back of the outboard brake pad. Compress the brake caliper piston into brake caliper bore to allow the piston enough clearance to slide the brake caliper off the brake rotor.
  6. Remove the C-clamp.
    NOTE Be sure to plug the opening in the brake caliper and brake hose to prevent fluid loss and/or contamination.
  7. Remove brake hose to caliper bolt attaching the brake hose to the brake caliper.
  8. Remove the brake hose from the brake caliper.
  9. Remove and discard the two copper brake hose gaskets. These gaskets may be stuck to the brake caliper and/or the brake hose end.
  10. Remove the park brake cable bracket from the brake caliper. Leave the park brake cable attached to the cable bracket.
  11. Disconnect the park brake cable from the park brake lever on the brake caliper.
  12. Remove the lower brake caliper pin bolt.
  13. Rotate the brake caliper up.
  14. Remove the brake caliper from the upper brake caliper pin bolt.
To install:
  1. If reusing the brake caliper retainers, clean the sleeves using denatured alcohol, or equivalent.
  2. Lubricate the brake caliper pin bolts with a thin coat of high temperature silicone lube.
  3. Install the brake caliper to the upper caliper pin bolt.
  4. Rotate the brake caliper down over the brake pads into the brake caliper bracket.
  5. Install the brake caliper pin bolts. Tighten the brake caliper pin bolts to 27 Nm (20 ft. lbs.).
  6. Remove the plugs in the brake hose end.
    NOTE Install NEW copper brake hose gaskets.
  7. Assemble the brake hose bolt and the NEW copper brake hose gaskets to the brake hose.
  8. Install the brake hose to caliper bolt to the brake caliper. Tighten the brake hose to caliper bolt to 44 Nm (33 ft. lbs.).
  9. Connect the park brake cable to the park brake lever on the brake caliper.
  10. Install the park brake cable bracket to the brake caliper. Tighten the park brake cable bracket bolt to 43 Nm (32 ft. lbs.).
  11. Install the front park brake cable to the park brake cable connector.
  12. Bleed the brake system.
  13. With the engine OFF, gradually apply the brake pedal to approximately 2 / 3 of its travel distance.
  14. Slowly release the brake pedal.
  15. Wait 15 seconds, then repeat until a firm brake pedal is obtained. This will properly seat the brake caliper pistons and brake pads.
  16. Install the tire and wheel assembly.
  17. Lower the vehicle.
NOTE The Bosch 2U ABS system cannot increase brake pressure above master cylinder pressure applied by during braking. There is no need to depressurize the system prior to service.
  1. Remove brake fluid from the master cylinder reservoir until the reservoir is approximately 1 / 3 full.
  2. Remove the front wheel. Mark the position of the wheel to the wheel studs, prior to removal, for installation reference.
  3. Install 2 lug nuts to retain the rotor once the caliper is removed.
  4. Using a large C-clamp, bottom the piston in the caliper bore by positioning the C-clamp on the outboard pad and on the round portion of the brake caliper where the piston is housed.
  5. Remove the banjo bolt that fastens the brake hose to the brake caliper. Discard the gaskets.
  6. Cap the brake line to avoid excessive fluid loss or fluid contamination.
  7. Remove the rubber dust boots from the caliper mounting bolt heads (if equipped).
  8. Remove the caliper mounting bolts.
  9. Remove the park brake cable from the caliper.
  10. Remove the caliper from the vehicle.
  11. Remove the brake pads.
To install:
  1. Install the brake pads. Lubricate the slides where the caliper mounts on the steering knuckle with silicone grease.
  2. Install the caliper over the rotor.
  3. Install the caliper mounting bolts. Torque the mounting bolts to 38 ft. lbs. (51 Nm).
  4. Install the park brake cable.
  5. Install the rubber dust boots over the caliper mounting bolt heads (if equipped).
    Fig. Measuring the caliper clearance
  6. Check the clearance between the brake caliper and caliper bracket stops. If the clearance is too tight, check the caliper leading and trailing edges for build up. File down as necessary.
  7. Connect the brake hose to the caliper. Install the brake hose banjo bolt, using new gaskets, and torque to 33 ft. lbs. (45 Nm).
  8. Remove the lug nuts used to secure the rotor.
  9. Install the wheel, aligning the reference marks made during removal, and torque the lug nuts to 100 ft. lbs. (140 Nm).
  10. Refill the master cylinder and bleed the brake system using the recommended procedure.
  11. Road test the vehicle and check for proper braking performance
Hope helps (remember rated this).
Jul 08, 2010 | 2003 Pontiac Bonneville
How to remove rear rotor after wheel is off
Disc Removal
  1. NOTE: When removing the rear brake disc (2C026) in this procedure it is not necessary to disconnect the hydraulic lines.
    Remove the rear disc brake caliper (2552).
1.Remove the brake caliper bolts (2W303).
2.Lift the rear disc brake caliper off the rear disc brake caliper anchor plate (2C220aca3301.gif
  1. NOTE: If the rear brake disc binds on the rear parking brake shoe and linings, remove the adjustment hole access plug and contract(push back to allow clearance) the parking brake shoe and lining.
  2. Remove the rear brake disc.
Feb 11, 2010 | 1998 Mercury Mountaineer
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
Remove and replace rear brake shoes on 2004 honda accord
Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Remove rear wheel assemblies.
  3. Release parking brake.
  4. Remove brake drum.
Rear brake shoe assembly
  1. Using an appropriate brake spring tool, unhook upper return spring from rearward brake shoe.
  2. Push retainer springs IN and turn to remove tension pins.
  3. Lower brake shoe assembly and remove lower return spring.
  4. Remove brake shoe assembly from back plate.
  5. Disconnect parking brake cable from lever and remove brake shoe.
  6. Remove parking brake lever from brake shoe.
To Install:
  1. Install parking brake lever to rearward brake shoe.
  2. Secure lever to brake show with a NEW U-clip.
  3. Pinch U-clip closed.
  4. Connect parking brake cable to rearward brake shoe.
  5. Install self-adjuster lever spring on front brake shoe.
  6. Assemble clevises, adjuster bolt and upper and lower return springs.
  7. Apply a light coat of grease (Molykote 44MA or equivalent) to sliding surfaces.
  8. Install brake shoe assembly onto back plate.
  9. Install tension springs.
  10. Using an appropriate brake spring tool, unhook upper return spring to rearward brake shoe.
  11. Install brake drum.
  12. Install rear wheel assembly.
  13. Lower vehicle.
  14. Adjust self-adjusting brakes by pressing brake pedal several times.
Jul 13, 2009 | 2004 Honda Accord
Rear brake rotor replacment
206-04: Rear Disc Brake 2000 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Disc Removal
    Remove the rear disc brake caliper (2552). For additional information, refer to Caliper in this section.
  2. Disconnect the brake hose.
  3. Remove bolt.
  4. Disconnect the rear wheel brake hose (2A442).
  5. Remove the copper washers and plug the brake hose.
  1. syn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not remove the guide pins or guide pin boots unless a problem is suspected. The guide pins are meant to be sealed for life and are not repairable. Use Silicone Brake Caliper Grease and Dielectric Compound D7AZ-19A331-A (Motorcraft WA-10) or an equivalent silicone compound meeting Ford specification ESE-M1C171-A for re-lubing the caliper slide pins. Other greases can swell the guide pin boots, resulting in contamination and accelerated corrosion or wear of the caliper slide pin mechanism.
    1. Remove the brake caliper bolts (2W303).
    1. Lift the rear disc brake caliper off the rear disc brake caliper anchor plate (2C220).
  1. Inspect the rear disc brake caliper for leaks.
    • If leaks are found, disassembly is required. Refer to Caliper in this section.
  1. NOTE: If the rear brake disc binds on the rear parking brake shoe and linings, remove the adjustment hole access plug and contract the parking brake shoe and lining.
  1. syn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use a hub-mount brake lathe if necessary to machine the rear brake disc.
    Measure the rear brake disc, and resurface as necessary. Install a new rear brake disc if beyond specification.
Mar 28, 2009 | 2000 Ford Explorer
Washing Machines Logo
13 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
