Question about Star Logic 17" LCD Monitor
Screen very muted out -- to light to read anything.
A RED BOX APPEARED ON THE SCREEN SAYING FACTORY R23-80B01 MODE. IN THE CENTER IT SAYS WAITING----ISP MODE
  • 558 Answers
You have a damaged pcb board inside the monitor, replacement of the board is easy (E Bay) or buy a new monitor.
Posted on Mar 21, 2009
Sony Bravia stuck in mute
The fault is with its main board itself. It will be best to get this set repaired by skilled technicians. This is not a user repairable one.
Aug 24, 2012 | Sony Televison & Video
Ipone 3gs restore factory setting code?
How to Restore iPhone 3G to Factory Settings
Make sure you are on the screen that holds your Settings icon. That is the icon with gears pictured in it. Touch the Settings icon.
In the Settings menu, touch the line that says General. It also has a picture of gears.
Scroll down the General page and you will see a line that says Reset. Select Reset.
This screen will show you several options you can reset including setting, home screen, keyboard dictionary, network settings and location warning. However, to erase all data, you will select the line that says Erase All Content and Settings. When you select it, a box will pop up with a red button saying Erase iPhone. There is also a warning saying it will delete all media and data and will take up to an hour. Touch the red button and your iPhone will format itself back to factory settings.
Tips & Warnings
Back up all data you want to save on your computer.
YOU WILL LOSE ALL DATA!!!!!
Also,
To restore iPhone and reset the phone to default factory settings, follow these steps:
1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
iPhone Recovery Mode
3. Plug the iPhone into Mac or Windows PC. Release the button if you haven't.
4. Run and open iTunes if it's not already opened yet.
5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
6. You will be taken to the iPhone pane. Then, click on Restore.
7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it's hardware related.
There is another mode called DFU mode which does not load the iBoot, and commonly used to downgrade the firmware and restore custom IPSW.
Use the link to below for DFU
mydigitallife.info/2010/10/25/how-to-enter-dfu-mode-in-iphone-ipad-and-ipod-touch-recovery/
Hope it helped.
Thanks for using fixya,..
Jan 15, 2011 | Cell Phones
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
Samsung LN22C350D1D FACTORY SETTINGS??
1. Do what you did, enter to service mode, and reset to factory default.
2. Use the component cable (green, blue, red, white, red) connect your set top box to the TV’s component input.
May 10, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Just got the CD445 Base Station. Red light keeps blinking
press the cid button then press menu then scroll through your missed calls then hit exit
Dec 26, 2008 | Philips ACCESSORIES & S60202 Earbud/Line...
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
Power outtage has my dlp hdtv actin weird
unhook everything from the tv and wait for a few minutes, go into the factory mode and do a reset, factory mode code is , mute-182-power
Jun 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Best but repleace bulb but red light still on
So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
Star Logic 17" LCD Monitor Logo
53 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
