Question about Jack Lalanne Power Juicer (Stainless Steel)
What type of motors used in juicer? - Jack Lalanne Power Juicer (Stainless Steel)
Jack Lalanne Power Juicer250
the power is not properly supplied to blade .....just check whether the connections are proper ....
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
ACME Supreme Juicerator sudden extreme vibration during juicing - top flew off...
These juicers vibrate, I don't care what anyone tells you.
Mine is 21 years old and I find using a worn resharpened
blade, after adjusting, lessens the vibration. If your not
close to being an auto mechanic, I suggest a pulp ejecting
type juicer like the Miracle MJ1000 for about $130.
May 22, 2010 | Acme 5001 Supreme Juicerator Juice...
Motor stops, electric burning odor, starts after cooling period
1-973-287-5150. VERY SHORT WARRANTY. IF OUT
OF WARRANTY GO FOR SOMETHING BETTER.
GOOGLE FERNS NUTRITION, THEY SELL JUICERS
AND GIVE GOOD ADVICE. I HAVE AN ACME SINCE
1990 AND RUNS LIKE THE DAY I GOT IT. TAKE A
LOOK AT THE LEXEN GP62. THE HUROM SLOW
JUICER IS GREAT, BUT BIG BUCKS.
Apr 01, 2010 | Jack Lalanne Power Juicer 250 Watts
Breville JE90J juice fountain spare part
The coupling on the juicer basket end is no big problem, but the coupling on the motor end is a big problem as you need to stop the motor from rotating to unscrew the coupling. This means remiving the base of the juicer which may be difficult because of the type of screws involved.
JE90/06 DRIVE COUPLING,
JE95/26 FILTER BASKET & DRIVE COUPLING
If you email me at sales@ewingelectrical.com.au I can help you with prices etc.
Mar 28, 2009 | Breville JE3 Juicer
When i use the power juicer leaks to all the place
it leaks because its too loose, try tighten it up....
Jan 14, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Power juicer not working
Hi my name is patricia you probably have to have the handle bars on or up so it can be tight and then the motor will run.
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
DOES NOT ROTATE
What type of juicer is this any model number?
if motor turn on and shaft rotate it should work is that the case?
Oct 13, 2007 | Matfer SANTOS Juicer
Jack Lalanne Power Juicer (Stainless Steel) Logo
35 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
dflynn2204
Level 1 Expert
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
