Question about Canon PowerShot A95 Digital Camera
Can't go into picture taking mode.
When I turn camera on, I can see the pictures on the card, but when I switch to the camera mode, there is no image on the screen. So I can't shoot pictures. Am I doing something wrong with the set, menu or other buttons. Very frustrating. Shel
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check this link: http://www.imaging-resource.com/badccds.html Accordint to this you can get a free repair, please contact the Canon dealer. Best regards, Arpi
Posted on Jul 18, 2007
SOURCE:
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
Mode switch has broken off and the camera screen says no image
it probably remained locked on the viewer and there are no images capture stored into the camera ..that's why it says that ....and it must be a way to restore the function of that button cause no matter if you lock it permanently into the the shooting mode its still a issue of getting pics out of it ....most cameras have to be on viewing mode when are plugged on the data cable ...but ..if you can open it and switch it on the mode that allow you to take pictures...you can always get the pictures from the SD card directly via an card reader ...adapter ( USB) that cost only a few dollars...
Aug 07, 2009 | Canon PowerShot S500 IXUS 500 Digital...
My brand new just put batteries in it powershot is displaying NO IMAGE. the lens won't even pop out! what the hell?
LOL, sounds like you're in "picture review" mode. Except that you haven't taken any pictures yet, so there's "NO IMAGE" on your card just yet. To take a picture, you need to put your camera in "camera" mode. Slide that tiny slide switch in the upper right all the way up until it's next to that little red camera. Now take a picture.
Jan 15, 2009 | Canon PowerShot A590 IS Digital Camera
Can't turn off/disable optimize image screen- nikon d80
Ok, all you need to do is:
1.Hold the camera normally like you would take a picture.
2.Turn it on and review a picture.
3. While looking at a picture, take your index (pointer) finger and rotate the front "wheel" right under the shutter release button. This switches the viewing mode, and should solve your problem.
Jan 12, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera LCD - black pictures
When I take a picture, there will be know image. Black. I went into the "share" and the image is black. I kept my smart card and the other images are ok but the knew ones are black. Camera has power. I took the smart card off. Still the problem, black. Took the old images off and took some more shots. All black!! MMMMM?
Sep 02, 2008 | Kodak EasyShare DX4330 Digital Camera
Problem
Two things to try...
A) If you have a card with some photo's on it then put it in the camera... Will the camera display the photos from the card in view/play mode? If so then the screen is working but the sensor in the camera may have died (the but that captures the image).
B) Try taking a picture with the camera (go through the steps to take one even though you can't see anything on the screen). Then put the memory card in a reader or a friends camera and see if the picture did get taken. If so then the sensor is still okay and the fault may be with the display.
If the display will show images from the memory card but doesn't show anything when in picture-taking mode but the camera does take pictures then the camera has a fault that isn't either the sensor or the LCD. It could then be an electronic failure or a problem with the mode selection switch.
Hope this helps to figure it out.
Cheers,
TS
Jan 04, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Fuji S3000 wont take pictures
Check for corrosion or dirt in your cameras battery compartment.
Jun 04, 2006 | Fuji FinePix S3000 Digital Camera
Canon PowerShot A95 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
