Question about Sony Handycam DCR-PC110 Mini DV Digital Camcorder
Sony DCR-PC110E - can I charge the battery through USB?
I have lost my battery charger kit and was wondering if I could charge the battery when plugged into camera via USB. Basically I've connected my Sony DCR-PC110E to my computer via USB, will this charge battery?
No man u can"t....in all sony brands the mini usb is meant only for data transfer...so better you go for a an ac power adopter...mail me at sharuputta@gmail.com
Posted on Sep 20, 2009
I have been made to do this my DCR-SR30 SONY HADDYCAM WONT CHARGE I MADE THE usb one is it any good
the USB charger is not usable, you will get separate charger in the market fit the battery on this charger,plug in this will be helpful.
Mar 03, 2016 | Sony Video Cameras
Lost my DCR-SR30 SONY BADYCAM CHARGE can you help me out
hi,
no matter, you will get a separate charger from the market, it is helpful to charge the battery, charger costs $20 only. go with your battery.
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
  1. Make sure the battery is firmly attached and the AC adapter is securely connected.
  2. If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
  3. Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
  1. If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
  2. Make sure the metal contacts on the battery are free of corrosion.
Dec 28, 2012 | Sony Handycam DCR-SR80 HD Camcorder
Sony PC110E video camera that is not recognised by PC
Buy a 4 to 4 pin or 4to 6 firewire cable (depending of Your PC model). Connect it to PC. In any case, the system must to recognize firewire device and capture the images. If PC don't want to see Your cam via direct firewire connection it means the firewire out is broken and needs to be repaired.
Sep 10, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Lost my charger trying to figure out how charge?
You normally charge the battery directly with the adapter that came with the camera.
To order a spare battery and charger go to
http://www.eastcoastphoto.com/nav/bfinder.asp?category=Camcorders&manufacid=13&itemno=DCR-DVD610&trng=AW&gclid=CLLIxqXUn5wCFRlcagodrgjXeA
You may be able to order the lost direct charger from them also.
Please rate this solution. Thanks.
Aug 13, 2009 | Sony DCR-DVD610 DVD Camcorder
Can i transfer video images taken on my dcr-pc110e sony camcorder to pc via a usb lead or can i only do it with a dv lead
You can do that using a USB cable that's one of the great features of this unit that you can already transfer files via USB to your computer.....
Jun 07, 2009 | Sony Handycam DCR-PC110E Mini DV Digital...
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
Feb 09, 2008 | Sony Handycam DCR-PC110 Mini DV Digital...
Charging of the battery
Hello, this should be simple. Conect the charger with the camcorder, and put the camcorder power switch in off position. Here is the link: http://support.sony-europe.com/dime/camcorders/DV/DV.aspx?l=en&m=DCR-HC19E Best regards, Arpi
Jul 14, 2007 | Sony DCR-HC19E Mini DV Digital Camcorder
Sony Handycam DCR-PC110 Mini DV Digital Camcorder Logo
781 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
