Question about Ariens 34 In. Zoom Series Riding Mower
Ariens riding lawn mower
Sorry I didn't include enough info. The model is 927046-RM1028. Trying to remove the front wheel. Is it held on with a bolt and if so what size socket will fit. Does the part the hub cap is mounted on come off when you remove the bolt or does it have to be removed in some special way. Thanks much for your help.
  • clintw864 Jan 27, 2009
    Thanks much. This is my first encounter with fixya but certainly won't be my last. Glad I found the site. Clint
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
bargainbin2
  • 123 Answers
SOURCE: How do I remove the groove pin from the arm on the
You will need a pair of C clip pliers.
Posted on Aug 26, 2009
mickey813
  • 472 Answers
SOURCE: Ariens Riding Mower Model #927025. Safety
you cant you need to get it to a shop to get that fixed
Posted on Oct 01, 2009
  • 81 Answers
SOURCE: Ariens ride on mower
The most likely cause of the mower belt coming off is a bearing in the quill assembly which are the upright units that have the pulley on top and the mower blade on the bottom, what usually happens is a bearing statrts to go bad, which allows the pulley to startmoving out of alignment with the other pulleys which causes the belt to ride up on a flange and come off. Usually I reccommend that when you replace one bearing or complete quill assembly you replace all bearings, or quill assemblies this way everything is in like new condition and the problem should be solved. Hope This Helps Don
Posted on Nov 10, 2009
Testimonial: "Thank you for your imput will fix my problem. Iam also looking for an Ariens rear mount 1028 model number 927023 serial number 004145 workshop manual "
SOURCE: Trying to find an operators manual for a ariens
Ron, I have a Arfiens 1540 ZTR and found my info here.
ight take some searching with model or serial number. Good Luck. Brian
http://partsradar53.arinet.com/scripts/EmpartISAPI.dll?MF&app=ARNC531&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer&partner=ARNC
Posted on Jun 27, 2010
1028 rear engine riding lawn mower model # 927046 is not moving when in gear. Was told I needed a drive box unit for it
check to see if the key in the axle is in place or if you put it in gear the axle turns in the wheel . is the pulley in place and not loose. the belt is good you said. but the pulley may be stripped. (axle key, belt, pulleys, or belt off of pulley)
Nov 19, 2016 | Garden
Ariens 42" lawntractor front wheels aren't straight
adjust the toe in -out and if they lean in at they top check bearings or king pin wear
toe in should be slightly in at the front(1/8 ") and wheels straight up and down
May 06, 2016 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
How do I fix a front wheel on my lawnmower from falling off?
Most Lawn mower wheels are held on with special bolts. If your wheel is loose enough it falls off you need to make sure there are washers and a nut that goes on the inside of the wheel. Tighten it up real tight but don't strip the bolt.
If the bolt is stripped you may need to purchase a new bolt and nut.
Sep 30, 2014 | Garden
Adjust the steering for an ariens 42" riding lawn mower?
sure there is nothig bent on front unhook the tie rod ends straighten the wheels then adjust tie rod to wheels hook back up done
Sep 16, 2014 | Garden
How do i change the blades on a 42in zoom z turn
raise the front of the mower to gain access to the underside where the blades are, using the right size wrench undo the bolt or bolts that hold the blades on and remove them from the mower, replace the blades and tighten the bolts to the required torque, lower the mower to the ground and take it for a test run.
May 19, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Which way do you turn the bolt on the blades of an ariens riding mower
You turn the bolt in the opposite direction on the the way the blades spin.
Jan 26, 2013 | Ariens 42" Riding Lawn Mower Blade ...
Jun 21, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
395 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
