Question about Emerson Televison & Video
How to connect DVD player to Emerson lc320em2 with red white and yellow wires
informatica
  • 1114 Answers
SOURCE: Connections on back of TV
You can download the manual from the link below: http://www.emersonaudiovideo.com/pdf/om/EWL3706.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 16, 2007
SOURCE: Connecting Wii to Emerson 37 in LCD tv
Finally found the correct point of entry to tv and correct channel on my own.
Posted on Dec 26, 2008
SOURCE: TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Posted on Dec 29, 2008
SOURCE: connecting ipod to samsung lcd tv
how to connect I-pod to samsung lcd tv
Posted on Oct 16, 2009
Nomodo4u
  • 863 Answers
SOURCE: need to connect dvd player
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Posted on Nov 05, 2009
How do I hook up this flat screen tv to my dvd
TV,s and DVD,s usually provide wiring diagrams to connect them together. Basically the "output" Connections of the DVD will go to the same "Input" connections on the TV. Most are colour coded. Red to red, blue to blue, yellow to yellow. These connections are usually marked Sound Left, Sound right, and video. If the DVD and the TV both have separate sound and video connections, or an "s" video output / input , use those as you will get a better picture and sound. For the standard RCA plug connections all you will need is the standard 3 colour lead to connect them. If you have the fancy S Video connections , you will need the special cable for this. Any good TV sales or electronic sales shop will have them.
May 26, 2015 | Emerson LC320EM2 32" LCD HD Television
I have a Emerson model LC320EM3F-A TV style ME2A1236181115. The model number for the Magnavox DVD Player is MDV2100/F7. How do I get it to work?
usually plug the proper wires from the DVD player into the proper input jacks on TV then select the proper input to the TV thru the menu
May 04, 2015 | Emerson Televison & Video
Why does my emerson 32In TV not find a channel for the DVD player that is running?
Check all the input connections once again. Check input cords. Change the cord and check. Sounds you have connected it to receive signals as AV. Select the input at TV to AV. If colors of the wire connected doesn't match the colors of the sockets at both TV and DVD end; this type of fault can occur. Anyway, check the connections and the colors of socket & wire do match, once again.
If all are found ok; and still you do not get signals, the main board to your TV should be troubleshooted. Contact any service technician.
Electro help
Feb 07, 2015 | Emerson Televison & Video
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
I have a philips dvd player and i want to connect it to my videocon lcd tv please help me in the wirings. any help with images will be appreciated thanking you in anticipation
the philips DVD player output gives three wire RED,WHITE,YELLOW accrording to them connect the red & white wire to the TV's red&white wires which is responsible for audio output from the dvd player,
then connect the yellow wire to the yellow inlet of the TV, which is either on the front pannel or back side of the television which is provides the video signal from the DVD.
Feb 16, 2011 | Televison & Video
How do i hook up my dvd player
Get the appropriate cord for connecting the DVD player to the TV.
The chord should be three joined together. Its called an AV wire. It has yellow, white and red color at the mouth of the pin.
The yellow is for Video (Visual) while the red and white are for audio (sound).
Since the DVD is to show on the TV, the wire has to be connected as follows:
  1. Insert the yellow wire in to the yellow part of the video out of the DVD.
  2. Insert the white and red wire in to the white and red part respectively to the audio out of the DVD.
  3. Connect the other part of the yellow wire to the input of the TV
  4. Connect the white and red wire to input like wise.
  5. Put on the TV and select to AV from the TV remote and you will see a display of your DVD at the background of the TV.
At this stage you can start watching.
Take care.
Jan 01, 2010 | GE 27GT271 TV
What cords are needed?
Yeh rca jacks,,the yellow is video and the red and white is audio,,
Oct 05, 2008 | Emerson EWD2204 DVD Player/VCR
PLAYING DVD
check your connections on the back of the tv and back of the dvd player. make sure you are using the proper conections on the back of the tv. if you connect the RCA (composite) cables (red yellow white) you should be going from the red yellow white on the tv to the red yellow white on the dvd player. if you have the component(red blue green) connection on the dvd connected to the red yellow white on the tv, you may get a black and white picture. If this does not work, check the manual for the dvd player and see if there is a way to turn "Progressive Scan" features off, some older TV's cannot handle a progressive scan dvd player.
Aug 13, 2007 | Koss KS2503 System
Televison & Video Logo
193 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
