Question about Dryers
I have a hotpoint aquarius ctd00g dryer.when i turn it on the power comes on but the drum does not spin.
  • karlturnbull Jan 26, 2009
    I CHECKED THE BELT AND ITS NOT BROKEN.
    Genius:
  • 2,920 Answers
Either the motor is stuck or the belt is broken or has slipped off the tensioner.
Posted on Jan 26, 2009
  • Ronnie Houston Jan 26, 2009
    then it may be the motor
Hotpoint aquarius tvm570 dryer
Either the belt is broken or possibly the motor starter has failed. Very often the belt. Be warned though, modern day tumble dryers use stretch belts that can be very difficult to fit.
Oct 18, 2013 | Hotpoint Dryers
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
My hotpoint aquarius ctd00 dryer won t spin when turned on but makes noise and heats up
We have made a few videos on these dryers and there are some very good repair guides on these.
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair
Jun 26, 2012 | Hotpoint Aquarius WD63 Front Load...
Drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint Aquarius WMA37 - the drum is not turning, even by hand
Remove rear panel of washer, slip the belt off, then try the drum to see if it turns, if it does, then the motor is the problem, if it does not, then the main bearings have siezed, or there is something fast between the inner and outer drum..
If it was noisy on spin prior to this happening, then it is more than likely the main bearings that have siezed.
Plz rate my solution.
Thanks.
THAN
Jan 10, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
171 people viewed this question
Top Dryers Experts
